Thread: Oracle DataTypes - DOUBLE?
    Mar 2004
    Bangalore
    Is there any DOUBLE Data Type in Oracle?
    if so pls tell me
    if not what is the alternate?
    Pratap
    Jun 2003
    Saudi Arabia
    Hi !!
    You can define a column with datatype "Double Precision" in Oracle .. but by default Oracle is treating it as its "Float" datatype.... Double Precision is just there for the ANSI support.
    create table mna (fi double precision);
    SQL> desc mna
    Name Null? Type
    FI FLOAT(126)
    Hope it will be helpful.
    Nadeem
    Geneva Switzerland
    From the SQL manual:
    The FLOAT datatype is a floating-point number with a binary precision b. The default precision for this datatype is 126 binary, or 38 decimal.
    The DOUBLE PRECISION datatype is a floating-point number with binary precision 126.
    So I don't think you're doing any better than with NUMBER.
