    Very slow Oracle installation with file system settings
    Environment:
    Oracle 9.2.0.1
    Solaris 8
    Veritas Volume Manager 3.0.4
    System: Sun E250 with dual ~300MHz CPUs and 6 internal disks; 2 in rootdg, the other 4 in RAID 5 with no logging
    Based on some recommendation of Metalink, I set the following options for mounting a vxfs file system:
    -o mincache=direct,convosync=direct,largefiles
    However, I notice once I mounted with the options and start installing Oracle 9.2.0.1 to the file system, it takes very long time to install. After inserting CD #2 6 hours ago, it is still installing from the CD. Same thing happened to CD #1. The java process spawned from the installation program uses 80+% CPU constantly.
    There is no failure in the RAID 5. Can someone suggest how to troubeshoot this?
    Thanks!
    greenwich.ct.us
    1. Don't install from CD.
    2. Are any of the disks 100% busy?
    marist89@yahoo.com
    http://marist89.blogspot.com/
    Get Firefox!
