problem with select..into inside a proc
Results 1 to 8 of 8
Thread: problem with select..into inside a proc
    May 2001
    Unhappy problem with select..into inside a proc
    Here is my proc --
    CREATE OR REPLACE PROCEDURE test_proc
    (i_tblname IN varchar2,
    i_whereClause IN varchar2,
    i_orderbyClause IN varchar2,
    i_ID IN integer) AS
    v_result VARCHAR2(100);
    v_sqlstmt VARCHAR2(1000);
    -- table MyTest(testID integer not null PK, testName varchar2(100))
    v_sqlstmt := 'SELECT testName INTO v_result FROM myTest WHERE testID = i_ID';
    IF i_WhereClause is not null THEN
    v_sqlstmt := v_sqlstmt + i_WhereClause;
    END IF;
    IF i_OrderByClause is not null THEN
    v_sqlstmt := v_sqlstmt + i_orderbyClause;
    END IF;
    EXECUTE IMMEDIATE v_sqlstmt;
    dbms_output.put_line('testName is : ' || v_result);
    EXCEPTION
    WHEN OTHERS THEN
    DBMS_OUTPUT.PUT_LINE(sqlerrm);
    The procedure will be created successfully, but if I tried to run it, it will keep giving me the following error
    ORA-00905: MISSING KEYWORD
    I know it must be caused by the INTO keyword inside the SELECT statement. But I do need to get the result back. My guess is I would need to use certain package from Oracle (say, DBMS_SQL etc) to solve this, is that right?
    Any hint is greatly appreciated!
    AL
    Try changing it to:
    v_sqlstmt := 'SELECT testNameFROM myTest WHERE testID = i_ID';
    and then
    EXECUTE IMMEDIATE v_sqlstmt into v_result;
    The EXECUTE IMMEDIATE statement runs the sql stmt exactly as you would outside of the proc, so it doesn't recognize the INTO keyword.
    JDF
    May 2001
    Thumbs up
    Thanks, that worked!!!
    BTW -- I was able to do 'select..into..from..where..' outside the proc, so I'm not quite sure about your last statement. So why it's not being recognized inside the proc?
    Originally posted by JDF
    Try changing it to:
    and then
    JDF
    Geneva Switzerland
    Does this work with varchar2?
    (is it new in some version?)
    Colorado Springs
    Just the syntax of the language. I guess that within the execute immediate clause the sql engine does not have visibility of the variable.
    By the way, I'd personally prefer dropping the "IF" blocks. They aren't required, and the code will be easier to support and a tiny bit faster ...
       v_sqlstmt := 'SELECT testName FROM myTest WHERE testID = i_ID';
       Execute Immediate
          v_sqlstmt||i_WhereClause||i_orderbyClause
          INTO v_result ;
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Geneva Switzerland
    I think you'll want some spaces in that concatenation (which is why I was acting dumb about +).
    May 2001
    Sorry, the '+' is a typo, it should really be '||'.
    AL
    Sorry that was first thing this morning, I was still having a hard time communicating....
    I meant that the EXECUTE IMMEDIATE basically runs the statment outside of the PLSQL block. So the "into variable" syntax is not valid.
    You'll get the same error if you log into SQL*Plus and run:
    select sysdate into v_result from dual;
