Results 1 to 10 of 10
    newbie5 is offline Call me super inquisitive
    Jun 2002
    Strange problem with database
    I am having a problem where, after stress tesing a java app on my database using load runner, the database crawls. The strange thing is the application completes successfully.
    Then sys connection takes 10 mimutes. Query to a dbs_users takes half an hour. These are the checkes I made:
    1. Nothing in the alert log other than log switching.
    2. No trace files at all regarding any error bdump and udump
    3. The database is not on archivelog mode.
    How to solve this problem. Where to look?
    Colorado Springs
    Have you usedstats pack to see what the delays are due to?
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Sounds like the Flux Capacitor.
    MH
    Jun 2002
    I cannot even run statspack report because it takes forever. Each line slowly displays after 10 minutes.
    This is W2K server running 9.2.0.4.
    Feb 2004
    Are you saying it takes 10 minutes to login?
    Usually when I have problems like this in Windoze, the CPU in task manager is pinned. Did you look at task manager? Sort the apps by CPU time, that should point you in the right direction, short of a networking problem.
    MH
    Is your java application running on the db server?
    Tamil
    Jun 2002
    Connect is Ok. But select dbname from v$databse takes 10 minutes before coming back with connected.
    I locked the XDB schema. I was told that there is a 9.2.0.4 bug that does that if XDB schema is not locked. But I did lock this schema.
    Where do I look if select count(*) from user_tables does not come back and the session hangs.
    Geneva Switzerland
    As Mr.H says look at task manager, also have a look at the disks: the flashing lights might indicate some unexpected activity (e.g. paging).
    I have NT Performance Monitor running permanently on my servers, with a window of 10+ minutes. In cases like this, if I run fast, I can see a picture of the server activity, before and after the onset of the problem.
    [Look on this site for QuickSlice which shows CPU per sub-process (i.e. "inside" oracle.exe) that task manager does not show. Unfortunately with response so bad, you'll have problems correlating that with anything the v$ views show you.]
    PS: link for quick slice and a useful Meatlink
    http://forums.dbasupport.com/forums/...ght=quickslice
    Jun 2002
    ri Feb 27 12:58:01 2004
    Errors in file e:\oracle\admin\rnjesm\udump\rnjesm_s006_2196.trc:
    ORA-00600: internal error code, arguments: [16365], [0x3A11D34C], [0], [4], [], [], [], []
    Fri Feb 27 12:58:30 2004
    found dead shared server 'S006', pid = (16, 1)
    Fri Feb 27 12:59:37 2004
    Errors in file e:\oracle\admin\rnjesm\udump\rnjesm_s016_3344.trc:
    ORA-00600: internal error code, arguments: [16365], [0x3A11DD78], [0], [4], [], [], [], []
    Fri Feb 27 13:00:13 2004
    found dead shared server 'S016', pid = (28, 1)
    I bounced the database and now this showing up in the init.ora.
    This seems to be a 9.2.0.4 bug apparently with no resolution from oracle.
