Results 1 to 9 of 9
    Apr 2003
    urgent help required regarding PL/SQL table
    I am trying to do manipulations in a PL/SQL table. And I am getting the following error. Please solve the error.
    SQL> DECLARE
    2 TYPE DeptTabTyp IS TABLE OF dept%ROWTYPE
    3 INDEX BY BINARY_INTEGER;
    4 dept_tab DeptTabTyp;
    5 begin
    6 FOR i IN dept_tab.FIRST .. dept_tab.LAST LOOP
    7 INSERT INTO dept (deptno, dname)
    8 VALUES (dept_tab(i).deptno, dept_tab(i).dname);
    9 END LOOP;
    10 end;
    11 /
    DECLARE
    ORA-06502: PL/SQL: numeric or value error
    ORA-06512: at line 7
    When you start your for-loop, your pl/sql table is empty. So both dep_tab.FIRST and dept_tab.LAST return NULL. So in fact your for-loop statement is like this:
      FOR i IN NULL .. NULL LOOP
      END LOOP;
    This of course results in "ORA-06502: PL/SQL: numeric or value error".
    You should first populate your PL/SQL table with som data before you reference it in for-loop.
    Apr 2003
    how do first populate my PL/SQL table with some data before i reference it in for-loop.
    please help
    Slovenia
    if you want, you can use bulk collect
    SQL> DECLARE
    5 begin
    select * bulk collect into dept_tab
    from dept;
    9 END LOOP;
    10 end;
    11 /
    or you can fill it like this
    dept_tab(1).deptno:= 10;
    dept_tab(1).dname:='name1';
    dept_tab(2).deptno:= 20;
    dept_tab(2).dname:='name2';
    Andrej
    Apr 2003
    1 DECLARE
    5 begin
    6 select * bulk collect into dept_tab
    7 from dept;
    8 FOR i IN dept_tab.FIRST .. dept_tab.LAST LOOP
    9 INSERT INTO dept (deptno, dname)
    10 VALUES (dept_tab(i).deptno, dept_tab(i).dname);
    11 END LOOP;
    12* end;
    13 /
    ERROR at line 6:
    ORA-06550: line 6, column 10:
    PLS-00103: Encountered the symbol "BULK" when expecting one of the following:
    from into
    Please solve this error
    Slovenia
    Maybe problem is this( i didn't look very close)
    if you have version 9... you can use
    DECLARE
    TYPE emp_type IS TABLE OF emp%ROWTYPE
    t_emptab emp_type;
    SELECT *
    BULK COLLECT INTO t_emptab
    FROM emp;
    FOR i IN 1..t_emptab.COUNT LOOP
    DBMS_OUTPUT.PUT_LINE(t_emptab(i).ename);
    -- here i have lot of code....
    DBMS_OUTPUT.PUT_LINE(t_emptab(i).empno);
    END LOOP;
    if you have version <9 you must declare every field
    DECLARE
    TYPE empno_type IS TABLE OF emp.empno%TYPE
    TYPE ename_type IS TABLE OF emp.ename%TYPE
    t_empno empno_type;
    t_ename ename_type;
    SELECT empno, ename
    BULK COLLECT INTO t_empno, t_ename
    FROM emp;
    FOR i IN 1..t_empno.COUNT LOOP
    DBMS_OUTPUT.PUT_LINE(t_empno(i));
    DBMS_OUTPUT.PUT_LINE(t_ename(i));
    END LOOP;
    Andrej
    Apr 2003
    hi andrej
    DECLARE
    t_empno empno_type;
    t_ename ename_type;
    SELECT empno, ename
    FROM emp;
    END LOOP;
    ERROR at line 10:
    ORA-06550: line 10, column 14:
    PLS-00385: type mismatch found at 'T_EMPNO' in SELECT...INTO statement
    ORA-06550: line 9, column 1:
    PL/SQL: SQL Statement ignored
    my oracle version is 8.0.5
    is it really because of version?
    Slovenia
    i heard thart bulk collect work in 8.1... and on
    so this(bulk collect) wont work in 8.0.5
    ther is link to documentation 8.0.5.
    http://otn.oracle.com/documentation/..._arch_805.html
    Andrej
    Apr 2003
    ok thanx a lot
