Pls tell me the docid
Can you please let me know the docid or url for the particular information on metalink. I tried searching a lot of documents on metalink but did not find any relavent information.
You've probably read this one if you've searched Metalink, but in case you havent it sounds a lot like your problem i.e. diconnects you and no msgs in alert log etc:
http://metalink.oracle.com/metalink/..._id=380583.995
Analyze also gives the same error
The docs talks abt bug in 9i but i am already on the higher release than the mentioned patch set. New finding is that the analyze table compute statistics also give the same error. But the file id mentioned with the 01114 error does not exist, how can I find error block without the right file id. Has anybody ever faced a problem of false file id with ora-01114.
Corrupt Blocks in that tab?
funky...
dbv gives no errors
But dbv does not identify any such block. How to get rid of this problem.
Problem Solved
The problem was with the Temp datafile. There was some OS corruption on it. So whenever the analyze used to use the tempfile extensively, it would abend. As the tablespace is locally managed we do not get proper info about the problem.
Thanks to all for the support.
Hi Apun
How did you zero down on the temp datafile ?what made you to look into the temp is the problem..
Hrishy
How did I find the problem
Actually analyze talked about a file id which does not exist.
I read a note on metaink, which indicated that if you are using locally managed tablespace, and the total no. of other datafiles are less than 100, the temp file id will start from 100. SO in my case the file id was 102, so I narrowed down to the tempfile3. I offlined it and then ran the same analyze it worked perfectly.
It took me a lot of time to find the right doc in metalink.
Some times the most unexpected ones help u out.
Thanks to all
