Thread: ora error
    south africa
    ora error
    I am newto linux.and I installed oracle 9i on Linux 7.1
    when I try to mount I get the following error
    ora-00209 : control file block size mismatch ..check alert log file
    my block size is 4 i gave
    What am i missing.do i need to set up any thing at OS level
    Pls help
    Saskatoon, SK, Canada
    On your alert.log did you see an ORA-218 error. You cannot just modify your primary block size.
    south africa
    well ..I installed the instance through dbca.by default the block size was 8 and i changed to 4.
    do you think that cuased.so i need to reinsatll the instance again
    thanks Sam for the help!!!
