Trigger Problem
I got a schema called Gary and another called SS
I m creating this trigger by loggin on to SS on Gary.G_Diary
what privileges do i need to have if any required.
If an insert is performed on Gary.G_DIARY i m inserting into my local table. I want to acheive this...but i m getting problems with :new and ld variables.
:new.gary.g_diary.columnname (can this be given)
Below is the code, Could anyone pl let me know whas wrong here.
Create or Replace Trigger Gdiary_ict
After Insert or Update or Delete on GARY.G_DIARY
for each row
declare
v_msg varchar2(100);
all_day varchar2(1);
recs number(8);
Begin
if inserting then
insert into G_DIARY_local (event_id,room_no,event,event_date,all_day,start_hour,start_mins)
values(ghall_eventdiary.nextval,:NEW.G_DIARY.ROOM_NO,:NEW.G_DIARY.EVENT,
:NEW.g_diary.event_date,'Y',:NEW.G_DIARY.HOUR_VALUE,:NEW.G_DIARY.HOUR_MINS);
end if;
end;
Do you have "CREATE ANY TRIGGER" priv?
Tamil
I want to create trigger in my schema.
SS
Let Gary should create public synonym on his table.
Then SS can reference the refer table w/o qualifier in the trigger.
I think it will work. I will also do my test.
Tamil
OK. I tested and it worked.
SS should have "CREATE ANY TRIGGER" priv, because SS is creating a trigger on a table that he has not owned.
You do not need use :NEW.tablename.columnname.
Just use :NEW.COLUMNAME.
Tamil
Thanks Tamil for the info.
got it working
SS
