    May 2003
    pro*c segmentation fault!!!!!!!
    I am using a make file to compile a pro*C program.I am able to compile and generate the executable.However while I am executing the program I am encountering a segmentation fault.It gives this fault on encountering a EXEC SQL statement.The following is a part of the code that is giving this fault.
    memset((char*)username.arr, 0x00, 20);
    strcpy((char*)username.arr, "user/pwd");
    username.len = strlen((char*)username.arr);
    fprintf(stdout, "DEBUG=Connect to database\n");
    EXEC SQL CONNECT :username;
    if (sqlca.sqlcode != OK) {
    fprintf(stderr, "\nUnable to connect - sqlca.sqlcode[%d]\n\n", s
    qlca.sqlcode);
    exit(NOTOK);
    Can anyone please help me with this?
    Aakhil
    Dec 2002
    Chennai, India
    Just try this......
    memset(username, 0,sizeof(username));
    strcpy(username, "user/pwd");
