Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Aug 2003
    performance with INSERT/EXCEPTION/UPDATE pattern
    I often use the logic below to load data from a query into a table. First I try to insert the row, and if it violates the pk constraint of the table I do an update instead.
    It seems that performance can be really slow when I'm dealing with a large number of updates. Maybe a factor of 10 longer than the case where it's mostly inserts. Is there a better way to perform this type of operation?
    FOR some_cursor_rec IN some_cursor LOOP
    INSERT INTO some_table(...
    EXCEPTION WHEN OTHERS THEN
    UPDATE some_table...
    COMMIT;
    END LOOP;
    Aug 2003
    Trying the update first, then doing the insert if SQL%ROWCOUNT is 0, seems to be a bit faster for heavy update cases, but still significantly slower than the same logic for heavy insert cases. I can't figure out why this is.
    Dec 2002
    Bangalore ( India )
    If Oracle Ver 9.2, use Merge ( its the fastest ).
    Abhay.
    funky...
    Colorado Springs
    Another approach would be to code it as a bulk operation, performing an insert, catching exceptions, and updating based on those exceptions.
    There's an example that you could use as a starting point here
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Dec 2002
    Bangalore ( India )
    If bulk operations can be done wass the need of "catching exceptions" in some other/temp table?
    can be done in jus 2 statements Insert(Not exists clause) & Update(Exists clause).
    Abhay.
    funky...
    Baltimore, MD USA
    But the other way around, of course.
    - Chris
    Christopher R. Long
    ChrisRLong@HotMail.Com
    But that's just my opinion. I could be wrong
    Baltimore, MD USA
    Another point, assuming it can't be done in bulk.
    As you mentioned, it helps to have an idea as to whether you will have more updates or inserts. And I don't see what there is to figure out there - it's kinda obvious.
    Anyway, the point is, if more updates:
    UPDATE ... WHERE EXISTS
    IF SQL%ROWCOUNT = 0
    THEN
    INSERT...
    If more inserts:
    INSERT WHERE NOT EXISTS
    IF SQL%ROWCOUNT = 0
    THEN
    UPDATE...
    Using the EXISTS or NOT EXISTS is more efficient than waiting for the exception.
    - Chris
    Christopher R. Long
    IF SQL%ROWCOUNT = 0
    THEN
    INSERT...
    If more inserts:
    IF SQL%ROWCOUNT = 0
    THEN
    UPDATE...
    - Chris
    I swear I've only had one beer today, but I'm totaly lost here. I'm not sure what are you talking about here.
    You are talking about update/insert of a record by record inside cursor, right? If so, why checking for existance at all? I mean, ROWCOUNT will tell if it exists or not, no?
    You are not talking about the same concept that slimdave has suggested, are you? Or have I totaly and 100% miss some important point here?
    I realy am confused.....
    Dec 2002
    Bangalore ( India )
    - Chris
    Chris :
    I didnt get what you wanted to tell, but lemme explain what I thought
    SQL%ROWCOUNT is not at all needed...(yes if using cursors, but not needed in bulk loads)
    jus see below eg
    Insert into X select %Attribute_List% From Y
    Where Not Exists (Select 1 From X Where PK_Of_X=Cols_Of_Y ( Or Sub Query ) )
    Update X Set (COLx1,COLx2,...) = (Select %Attribute_List% From Y Where Cols_Of_Y ( Or Sub Query )=PK_Of_X)
    Where Exists
    (Select 1 from Y Where Cols_Of_Y ( Or Sub Query )=PK_Of_X)
    Abhay.
    funky...
    Baltimore, MD USA
    Chris :
    jus see below eg
    Where Exists
    Abhay.
    Which, as I said, is simply in the wrong order You don't want to insert the records *before* the update, or you will end up updating those very same records (as well as the others), right? You always do the update before the insert. My next post was only applicable if bulk statements could not be done, as I specified at the beginning of said post.
    Okay, so in my haste, I went a *little* too far, but not by much.
    DROP TABLE JUNK
    CREATE TABLE JUNK AS SELECT ROWNUM PK, T.* FROM ALL_OBJECTS T
    CREATE UNIQUE INDEX JUNK_PK ON JUNK(PK)
    ANALYZE TABLE JUNK COMPUTE STATISTICS
    INSERT -- TEST02
    INTO JUNK
    SELECT * from JUNK WHERE PK = 1
    INSERT -- TEST02
    INTO JUNK
    AND NOT EXISTS(SELECT 1 FROM JUNK WHERE PK = 1)
    Compare the buffer gets on the two statements. The second one is much more efficient. Therefore, If more inserts:
    IF SQL%ROWCOUNT = 0
    THEN
    UPDATE...
    However, the same does not appear to apply to updates
    UPDATE -- TEST06
    JUNK	J
    SET
    	(PK,	OWNER,	OBJECT_NAME,	SUBOBJECT_NAME,	OBJECT_ID,
    	DATA_OBJECT_ID,	OBJECT_TYPE,	CREATED,	LAST_DDL_TIME,
    	TIMESTAMP,	STATUS,	TEMPORARY,	GENERATED,	SECONDARY
    	SELECT
    	FROM
    		JUNK
    	WHERE
    		PK	=	J.PK
    WHERE
    	PK	=	100000
    UPDATE -- TEST06
    JUNK J
    SET
    	SELECT
    	FROM
    		JUNK
    	WHERE
    		PK	=	J.PK
    WHERE
    	PK	=	100000
    AND NOT EXISTS(SELECT 1 FROM JUNK WHERE PK	=	J.PK)
    In this case, both statements run exactly the same.
    So, if more updates, simply:
    UPDATE ...
    IF SQL%ROWCOUNT = 0
    THEN
    INSERT...
    - Chris
    Christopher R. Long
