PO, which has a list of Purchase Order Numbers; ACTIVITY, which has a list of Activities, and INVOICE, which matches activities to POs. Some Activities and POs are matched more than once - this is because there may be multiple invoices to the PO on the same activity; however, some POs are charged to more than one Activity, based on line items. Invoice number isn't really relevant to this query.
ACTIVITY is joined to INVOICE on the activitynumber field. PO is joined to INVOICE on the ponumber field. There are no primary keys in any of the tables.
What I'm trying to do is create a query between INVOICE, ACTIVITY, and PO that will list only those PO numbers (ponumber) that are associated with ALL codes (code) in the ACTIVITY table.
select po.ponumber
from po
where not exists (select code from activity
minus
select activitynumber
from invoice i
where i.ponumber = po.ponumber)
Tomaž "A common mistake that people make when trying to design something completely
foolproof is to underestimate the ingenuity of complete fools" - Douglas Adams
select po.ponumber
from po
minus
from invoice i
