Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    difference between max(datecolumn) and max(to_date(datecolumn),'dd-mm-rrrr')
    hi all
    when i use
    select max(datecolumn) from atable ;
    it gives
    31-may-03
    but when
    select max(to_date(datecolumn),'dd-mm-rrrr) from atable ;
    it gives
    03-jul-03
    second query is giving correct result.
    please note that type datecolum is date
    what is the difference ???
    we r using win2000 and oracle 8.1.7
    P.soni
    Geneva Switzerland
    Re: difference between max(datecolumn) and max(to_date(datecolumn),'dd-mm-rrrr')
    This has two syntax errors - so I don't think this is what gave the output posted.
    Are you 100% sure? The results suggest that it is a character column - 31 is the highest value for the first two characters.
    Re: Re: difference between max(datecolumn) and max(to_date(datecolumn),'dd-mm-rrrr')
    PLEASE READ IT AS
    select max(to_date(datecolumn,'dd-mm-rrrr)) from atable ;
    YES ITS DATE COLUMN
    P.SONI
    Jul 2001
    Slovenia
    Re: Re: Re: difference between max(datecolumn) and max(to_date(datecolumn),'dd-mm-rrrr')
    PLEASE READ IT AS
    Still missing a quote here
    I believe datecolumn is a character column.
    Tomaž
    "A common mistake that people make when trying to design something completely
    foolproof is to underestimate the ingenuity of complete fools" - Douglas Adams
    Can't you please post the output of "DESCRIBE atable" from SQL*Plus session?
    When you say: "YES ITS DATE COLUMN", do you think anyone will belive you? I mean, with so many mistakes you have posted here in a simple "select max(to_date(datecolumn,'dd-mm-rrrr')) from atable;" ....
    SQL> desc atable
    Name Null? Type
    VRNO VARCHAR2(11)
    DATECOLUMN DATE
    text file attached
    Geneva Switzerland
    My guess is that your data includes two dates:
    31-MAY-2003 and 03-JUL-1903
    MAX(datecolumn) gives the correct value: 31-MAY-2003.
    What I think is happening in the second expression is:
    For the TO_DATE to work, datecolumn is somehow first converted to characters (it expects character input NOT a date - I'm surprised it does not give an error):
    03-JUL-03
    This then converted back to date with -RRRR becomes:
    03-JUL-2003
    which is bigger than 31-MAY-2003
    (All this can be avoided if you make sure your default date format includes YYYY).
    . . on the other hand I could be wrong.
    Jul 2001
    Slovenia
    Good one, I would never thought of this!
    Somehow means that it's implicitly converted to characters.
    If you input to_date function a date format that is compatible with default setting (used for implicit to_char conversion), it gives no error.
    Tomaž
    i have run query using format 'YYYY' output is something like
    below
    perhapes copy-paste is not proper... so i am also attaching text file
    SQL> select to_char(min(to_date(datecolumn,'dd-mm-yyyy')),'dd-mm-yyyy'),to_char(max(to_date(datecolumn,'dd-mm-yyyy')),'dd-mm-yyyy')
    2 from atable
    3
    SQL> /
    TO_CHAR(MI TO_CHAR(MA
    16-05-0003 02-07-0003
    SQL> select to_char(min(datecolumn),'dd-mm-yyyy'),to_char(max(datecolumn),'dd-mm-yyyy')
    2 from test.atable
    3
    SQL> /
    16-05-2003 31-05-3003
    1* select to_char(max(to_date(datecolumn,'dd-mm-yyyy')),'dd-mm-yyyy') from atable
    SQL> /
    TO_CHAR(MA
    02-07-0003
    SQL>
    we are noticing that by setting the session
    nls_date_format
    we are getting correct result
    the old nls_date_format was 'DD-MON-YY'
    new session is 'DD-MM-YYYY'
    I want to know if procedure/fuction will be affected by the session's parameter .
    soni
