Problem running SQL*Loader utility
I need to load data into a table. The flat file containing the data is around 2GB in size. When i am running the SQL*Loader utility on this flat file, the process and database seems to be going into a hang.
Do i need to make any changes to my control file below.
LOAD DATA
INFILE 'ORDERHDR_ALL.txt'
INTO TABLE ORDERHDR_ALL
FIELDS TERMINATED BY ',' OPTIONALLY ENCLOSED BY '\''
TRAILING NULLCOLS
OHXACT,
OHSTATUS,
OHSTATUSFLG,
OHENTDATE,
OHREFNUM,
OHTSHDATE,
OHSLS,
CUSTOMER_ID,
OHCSEQ,
OHSNAME,
OHSADDR1,
OHSADDR2,
OHSADDR3,
OHSCITY,
OHSST,
OHSZIP,
OHSCOUNTRY
Suvashish
Have you given a thought to DIRECT MODE LOAD? 2GB is pretty big, direct load can save you a lot of time and resources.
Sanjay G.
Oracle Certified Professional 8i, 9i.
"The degree of normality in a database is inversely proportional to that of its DBA"
SQl*Load
Yes. Below is the command i am executing.
$sqlldr userid=sysadm control=ORDERHDR_ALL.ctl log=ORDERHDR_ALL.log bad=ORDERHDR_ALL.bad direct=true
Suvashish
Possibly you can think of spliting file into 4 different files & can use Parallel Direct Loads.
And also, if ur DB in archivelog mode, you could bypass by using UNRECOVERABLE clause in control file.
funky...
How do i run the SQl*Loader in both parallel and direct mode at the same time.
I found that Parallel=TRUE & Direct=TRUE together in the sqlldr statement doesn't work
Suvashish
funky...
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
