    May 2003
    DEFERED Problem in Materialized Views Creation
    Hi .
    I want to create a updatable materialized view with the DEFERRED option. In other words just want to create a mv and dont want the DATA of the base table to be filled in at creation of this mv.
    It returns me back with the following error.
    "ORA-22992: cannot use LOB locators selected from remote tables"
    Here is my code
    CREATE MATERIALIZED VIEW xyz_mv
    BUILD DEFERRED
    REFRESH FORCE
    for update
    AS SELECT * FROM xyz@ORACLE.Net
    My xyz table contains a column of the LOB data type.
    I m working on Oracle 9i release 2.
    Its working fine if i remove the DEFERRED keyword, and will create an updatable mv with the LOB column. But i have to use this DEFERRED keyword as i m working on a WAN environment and dont want to put the load in it while creating the MV's.
    How am i going to create an updatable mv base on the table containing LOB columns.
    Suggesstions.
    RAFF
    New Delhi, INDIA
    Why do you keep asking the same question angain and again, with different Subject header.
    I think MH has answered your question. Read your previous threads. If not satisfied with the answers then contact Oracle Support. Closing duplicate threads.
    http://www.dbasupport.com/forums/sho...threadid=36918
    http://www.dbasupport.com/forums/sho...threadid=36909
    Amar
    Amar's Blog  Get Firefox!
