I have one doubt. I have set
cpu_count=12
Parallel_automatic_tunning = 'TRUE'
Parallel_max_server = 24 ( I have 12 cpus )
Parallel_min_percent = 4
Parallel_adaptive_multi_user =TRUE
Parallel_threads_per_cpu=2
As a result, default degree of parallelism is
cpu_count*Parallel_threads_per_cpu*(a reduction factor)
Now I want to use this default degree automatically for all tables. Now my question is : What the value should we provide for parallel cluase of create table statement so that default degree will
be calculated and that degree will be used in the sql where this table will be used ?
As I know If I give just
create table dept (deptno number ) --> it will have value for parallel clause as 1 (default value) as we
can check from dba_tables
What should be the value of parallel clause in this scenario where we want to use default degree which will be decided by oracle dynamically ?
Deba
