    Apr 2003
    Kuala Lumpur
    Alter system set auditing failed
    I issue 'alter system set audit_sys_operations=TRUE' but I got the following error. Pls help.
    Error:
    SQL> alter system set audit_sys_operations=TRUE;
    ORA-02095: specified initialization parameter cannot be modified
    New Delhi, INDIA
    That means this parameter cannot be modified dynamically. You need to make changes in the init.ora file and bounce the DB.
    HTH
    Amar
    Amar's Blog  Get Firefox!
    Feb 2000
    Singapore
    It is a static parameter.
    AUDIT_SYS_OPERATIONS
    Parameter type
    Boolean
    Default value
    false
    Parameter class
    Static
    Range of values
    true | false
    AUDIT_SYS_OPERATIONS enables or disables the auditing of operations issued by user SYS, and users connecting with SYSDBA or SYSOPER privileges. The audit records are written to the operating system's audit trail.
    Sanjay G.
    Oracle Certified Professional 8i, 9i.
    "The degree of normality in a database is inversely proportional to that of its DBA"
