    Question Problem with STATSPACK
    Hi Guys,
    Database: Oracle 8.1.7 EE
    OS: Solaris 7
    I would like to use STATSPACK. When I ran spcreate.sql got the following errors:
    $ cat spcusr.lis
    ... Installing Required Packages
    Package created.
    Grant succeeded.
    View created.
    Package body created.
    Package created.
    Synonym created.
    Grant succeeded.
    create view X_$KCBFWAIT as select * from X$KCBFWAIT
    ORA-00955: name is already used by an existing object
    Could you please explain why I am getting this?
    Thanks in advance.
    Cheers!
    Farrukh
    don't know what happened but you can certainly drop statspack and recreate it by doing the following:
    be sure using SQL not SVRMGRL
    1. log in as SYS
    2. run spdrop.sql to drop statspack
    3. log in as perfstat/perfstat
    4. run spcpkg.sql
    5. run statspack.snap
    Thanks for quick reply.
    I have done the same as you mentioned. After running spdrop.sql I tried to connect with perfstat user:
    test2:sys> @spdrop.sql
    test2:sys> conn perfstat
    Enter password:
    ERROR:
    ORA-01017: invalid username/password; logon denied
    Thanks once again for your time.
    Cheers.
    Farrukh
    if you open spdrop you see
    --  Drop PERFSTAT's tables and indexes
    @@spdtab
    --  Drop PERFSTAT user
    @@spdusr
    if you open spdusr.sql you see
    Rem
    Rem  Drop PERFSTAT user cascade
    Rem
    drop user perfstat cascade;
    Thumbs up
    Hi guys,
    After RTFM, found that if we need to run spcreate.sql as batch mode, we have to specify default & temporary tablespaces. Otherwise, it will create PERFSTAT user, tables, indexes and packages under SYSTEM tablespace.
    STATSPACK is ready to use now!
    Anyway, thanks guys for help!
    Cheers!
    Farrukh
