Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Query problem
    Query problem
    I am trying to do the following query. Query1 will error out. Query2 works. Question: Does Query2 call the DoCalculate twice for every row processed? (One in the select and one in where clause.) If yes, how do I reduce the number of call to the function to 1?
    Query1:
    select DoCalculate(aLongitude,aLATITUDE,a.LONGITUDE,a.LATITUDE) mileage_calcualted
    from TABLEx a
    where mileage_calcualted is not NULL;
    Query2:
    from TABLEx a
    where DoCalculate(aLongitude,aLATITUDE,a.LONGITUDE,a.LATITUDE) is not NULL;
    Colorado Springs
    Re: Query problem
    select * from
    from TABLEx a
    where mileage_calcualted is not null;
    Better if you can to express the function behind DoCalculate in SQL
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Re: Query problem
    No, not for every row processed. But, yes, for every row returned.
    For the rows where function DoCalculate() result in NULL, the function is executed only once (only in WHERE clause). Since in this case the result of the WHERE clause is "FALSE", Oracle doesn't bother to process that row further, so the DoCalculate() in selct column list is not executed. But for rows where DoCalculate() result in NOT NULL, function is executed twice - first time for the WHERE clause and the second time for column list.
    I'm not sure if it can be done, at least not with pure SQL. First I thought that the following will help:
    select mileage_calcualted from
    (select
     from TABLEx a
    however it turned out that it behaves exactly as the original query.
    Re: Re: Query problem
    Originally posted by slimdave
    select * from
    from TABLEx a
    That was my initial thougt too, however it turned out that DoCalculate() is still called twice for any row returned! At least on 9.0.1.
    Colorado Springs
    Grrr.
    OK, how about a subquery factoring clause?
    with sfc as
       select
          DoCalculate(
             aLongitude,
             aLATITUDE,
             a.LONGITUDE,
             a.LATITUDE) mileage_calculated
       from
          TABLEx
    select
       mileage_calculated
    from
       sfc
    where
       mileage_calculated is not null;
    'Owzat?
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Grrr.
    with sfc as
       select
          DoCalculate(
             aLongitude,
             aLATITUDE,
             a.LONGITUDE,
       from
          TABLEx
    select
       mileage_calculated
    from
       sfc
    where
    'Owzat?
    Gee! I didn't even know such a beast of a construct exists or is possible in Oracle (I wouldn't be surprised if I saw it in some Celco's article, though)! I see, it's realy time for me to dig into Oracle Manuals and start studying SQL again.
    Anyway Slimdave, as much as I hate to dissapoint or irritate you (Grrr?) - it still calls the function twice for any row returned !
    Re: Re: Re: Query problem
    How did you find out, even with an inline view, it still run twice for any row returned?
    Re: Re: Re: Re: Query problem
    Quite simply, I created a dummy function with DBMS_OUTPUT cals in it and observed how it behaves.
    CREATE OR REPLACE FUNCTION foo (p NUMBER) RETURN VARCHAR2
    IS
      dbms_output.put_line('EnterED function');
      IF p = 0 THEN
        dbms_output.put_line('Returned NULL');
        RETURN NULL;
      ELSE
        dbms_output.put_line('Returned NOT NULL');
        RETURN 'x';
      END IF;
    SET SERVEROUTPUT ON
    SELECT c1, xyz FROM
    (SELECT c1, foo(c1) xyz FROM t1)
    WHERE xyz IS NOT NULL;
    Colorado Springs
    I am the master of obscure syntax
    Doesn't work eh? Hmmm. It's supposed to create a temporary result, defined as sfc here, then query that. How odd.
    In the case of the first attempt i made, it might be doing some kind of "optimization" by pushing the predicate into the inline view.
    It's a real long shot, but maybe ...
    select /*+ NO_PUSH_PRED(Tablex) */ * from
    from TABLEx a
    Probably won't work because the hint is really to do with join predicates.
    Here's another desperate attempt.
    select * from(select (select DoCalculate(aLongitude,aLATITUDE,a.LONGITUDE,a.LATITUDE)
    from dual) mileage_calcualted
    from TABLEx
    where mileage_calculated is not null
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Nope, I've tried to fool it with some of the hints too (like NO_MERGE), but it doesn't work.
    from TABLEx
    Kudos!
    Now that's what I call "master of obscure syntax", but hey, it works! It realy calls function only once per row processed.
    Who cares if noone understands what the query is supposed to do, as long as it runs realy fast.
