Results 1 to 10 of 15
    May 2003
    India
    Problem In Normal Shutdown
    hi,
    One process was running in Oracle, that process has been killed.Since it will take 3 to 4 hrs to rollback the whole data.
    I have shutdown the database with shutdown abort.
    Then I brought it up.Then I again given the same process, but found that physical reads is not increasing.So shutdown abort given again.
    And now when i am going for Normal or Immediate Shutdown, it is not taking place.Once Normal shutdown given , but it has not done after running for 8 hrs.
    There is nothing abnormal in the log file.In this case what shall i do???
    Dec 2002
    Bangalore ( India )
    Re: Problem In Normal Shutdown
    Originally posted by dhiman_s
    hi,
    Do u mean now no processes are running (except backgroung)...and SHUTDOWN Normal or Immediate is not working?
    Or if that process(which u expect it wud take 3 to 4 hrs for rollback) is running and u give SHUTDOWN Normal..it took 8hrs time in vain doing nothing?
    funky...
    alter system checkpoint
    shutdown abort
    startup restrict
    do wehat you need to do here
    shutdown immediate
    startup
    Oct 2002
    hi, i did a shutdown immediate.. and it told me that i cant as one of the datafiles is still being backup. what happens earlier is that one of my backup scripts failed, so i suspect that this is the first datafile that is being backuped. i cant rememebr the exact oracle errro number nor the text. something along the line like "cannot shutdown, one of the datafiles is still being in backup"
    can i do "alter database open 'datafile' end backup; "
    please advise
    and why i want to shutdown immeidate is to switch off the archive log
    1) shutdown immediate
    2) startup mount
    3) alter (..........)
    thanks
    May 2001
    Check from V$backup view which datafile is in backup mode.
    Then use ALTER DATABASE 'DATAFILE' END BACKUP; or
    IF it 9i then u can use
    ALTER DATABASE END BACKUP
    Which takes out all the datafiles from backupmode.
    Oct 2002
    i did a select * from v$backup and got a list of 109 ACTIVE status.
    1) this means that there are 109 ACTIVE backups to go?
    2) shutdown abort; will have serious consequences on the database?
    please advise
    thanks
    Feb 2000
    Singapore
    please advise
    thanks
    Oracle Version ?
    Are you using RMAN or OS Scripts for hot backup ?
    Does your hotbackup script backup many tablespaces parallaly ?
    You can prepare a quick script like this.
    select 'alter tablespace '||tablespace_name||' end backup;'
    from dba_tablespaces;
    Sanjay G.
    Oracle Certified Professional 8i, 9i.
    "The degree of normality in a database is inversely proportional to that of its DBA"
    Oct 2002
    i am using unix scripts for my backup through tivoli. my oracle release is 8.0.6.3.0
    RMAN does not do begin/end backup....
    Oct 2002
    thanks everyone, the problem has been resolved...
    by alter tablespace end backup
