The first time I loaded Oracle our sysadmins did not have one of the math libraries loaded. They loaded the missing library. Then I reinstalled on top of what I had installed and got the error below. Then I completely wiped out what was there and installed 8.1.7 from scratch including installing the 8.1.7.4 patch. During this process I did not recieve any errors during the install but still got the error below when I went to use one of the Oracle tools.
The listener seems to start but I can not use any other Oracle binary. It is possible that there is some problem with the operating system.
The missing math library was bos.perf.libperfstat
/usr/oracle/9.2.0.2/bin: lslpp -l bos.perf.libperfstat
lslpp: 0504-132 Fileset bos.perf.libperfstat not installed.
Now it is installed.
Fileset Level State Description
Path: /usr/lib/objrepos
bos.perf.libperfstat 5.1.0.35 COMMITTED Performance Statistics
Library Interface
Code:/usr/oracle/8.1.7_32/bin: svrmgrl exec(): 0509-036 Cannot load program svrmgrl because of the following errors: 0509-130 Symbol resolution failed for svrmgrl because: 0509-136 Symbol pw_post (number 264) is not exported from dependent module /unix. 0509-136 Symbol pw_wait (number 265) is not exported from dependent module /unix. 0509-136 Symbol pw_config (number 266) is not exported from dependent module /unix. 0509-136 Symbol aix_ora_pw_version3_required (number 267) is not exported from dependent module /unix. 0509-192 Examine .loader section symbols with the 'dump -Tv' command. /usr/oracle/8.1.7_32/bin: /usr/oracle/8.1.7_32/bin: uname -a AIX aixserver 1 5 000133AA4C00
I am at a loss as to what is happening. Any relevant help would be appreciated. Thanks.
