bulk insert & rebuild indexes
Thread: bulk insert & rebuild indexes
    Dec 2002
    Hi All
    I have a table in db1 with 20 million records & 4 indexes.
    We are not using partioning.
    In db2 i have the same table with some additional columns .
    Now i want all the rows from table in db1 to table in db2
    along with the 4 indexes . after this i would be updating the
    new columns in db2.
    What would be the best approach . shall i go for sqlldr option
    Kindly give suggestions
    Sushant
    Sep 2000
    Chennai, India
    Do an export from db1 and import into db2 with ignore=y.
    You could create the indexes fresh in db2 after the import.
    BTW, do not forget to analyze the schema.
    HTH.
    SQL*LOADER is faster than import, but the data should be in flat file.
