Results 1 to 10 of 16
Thread: sql query tuning
    sql query tuning
    Hi All
    I have interesting query
    SQL> SELECT ttralnktix.CODAPP_OLD,
    2 ttralnktix.NUMTRAFRT,
    3 TPTFBDR_B.CODPTF codptfold ,
    4 ttralnktix.NUMTRAFRTLNK,
    5 ttralnktix.CODAPP_NEW,
    6 TPTFBDR_A.CODPTF codptfnew,
    7 ttralnktix.CURDATE
    8 FROM ttralnktix,
    9 TPTFBDR TPTFBDR_A,
    10 TPARCPTTIX TPARCPTTIX_A,
    11 TPARGESTIX TPARGESTIX_A,
    12 TPTFBDR TPTFBDR_B,
    13 TPARCPTTIX TPARCPTTIX_B,
    14 TPARGESTIX TPARGESTIX_B
    15 WHERE ( ( TPARCPTTIX_A.IDFTRA = TPARGESTIX_A.IDFTRA ) and
    16 ( TPARCPTTIX_B.IDFTRA = TPARGESTIX_B.IDFTRA ) and
    17 ( ttralnktix.NUMTRAFRT = TPARGESTIX_A.NUMTRAFRT ) AND
    18 ( TPARCPTTIX_A.CODTRSPTF = TPTFBDR_A.CODTRS ) AND
    19 ( ttralnktix.NUMTRAFRTLNK = TPARGESTIX_B.NUMTRAFRT ) AND
    20 ( TPARCPTTIX_B.CODTRSPTF = TPTFBDR_B.CODTRS ) AND
    21 ( ttralnktix.CODAPP_OLD = TPARGESTIX_A.CODAPPFRT ) AND
    22 ( ttralnktix.CODAPP_NEW = TPARGESTIX_B.CODAPPFRT )
    23 AND
    24 ( TPTFBDR_A.CODPTF = 'CROSB') )
    25 ;
    C NUMTRAFRT CODPTFOL NUMTRAFRTLNK C CODPTFNE CURDATE
    A 16553901 WARTS 11199599 A CROSB 10-APR-03
    A 19059202 WARTS 11199599 A CROSB 11-APR-03
    A 19059202 WARTS 11898559 A CROSB 10-APR-03
    Elapsed: 00:00:00.13
    Execution Plan
    0 SELECT STATEMENT Optimizer=CHOOSE
    1 0 NESTED LOOPS
    2 1 NESTED LOOPS
    3 2 NESTED LOOPS
    4 3 NESTED LOOPS
    5 4 NESTED LOOPS
    6 5 NESTED LOOPS
    7 6 TABLE ACCESS (BY INDEX ROWID) OF 'TPTFBDR'
    8 7 INDEX (UNIQUE SCAN) OF 'IPTFBDR2' (UNIQUE)
    9 6 TABLE ACCESS (BY INDEX ROWID) OF 'TPARCPTTIX'
    10 9 INDEX (RANGE SCAN) OF 'IPARCPTTIX2' (NON-UNI
    QUE)
    11 5 TABLE ACCESS (BY INDEX ROWID) OF 'TPARGESTIX'
    12 11 INDEX (RANGE SCAN) OF 'IPARGESTIX1' (UNIQUE)
    13 4 INDEX (RANGE SCAN) OF 'PK_TTRALNKTIX' (UNIQUE)
    14 3 TABLE ACCESS (BY INDEX ROWID) OF 'TPARGESTIX'
    15 14 INDEX (RANGE SCAN) OF 'IPARGESTIX2' (NON-UNIQUE)
    16 2 TABLE ACCESS (BY INDEX ROWID) OF 'TPARCPTTIX'
    17 16 INDEX (RANGE SCAN) OF 'IPARCPTTIX1' (UNIQUE)
    18 1 TABLE ACCESS (BY INDEX ROWID) OF 'TPTFBDR'
    19 18 INDEX (UNIQUE SCAN) OF 'IPTFBDR1' (UNIQUE)
    Statistics
    0 recursive calls
    0 db block gets
    508 consistent gets
    0 physical reads
    0 redo size
    1070 bytes sent via SQL*Net to client
    554 bytes received via SQL*Net from client
    2 SQL*Net roundtrips to/from client
    0 sorts (memory)
    0 sorts (disk)
    3 rows processed
    when i change the query to
    SQL> SELECT
    8 FROM ttralnktix,
    23 AND
    24 ( TPTFBDR_B.CODPTF = 'WARTS') ) ;
    A 16868993 WARTS 11199599 A ACTEU 10-APR-03
    A 17778227 WARTS 11898558 A CBWAR 10-APR-03
    Elapsed: 00:01:07.80
    Execution Plan
    1 0 NESTED LOOPS
    2 1 NESTED LOOPS
    3 2 NESTED LOOPS
    4 3 NESTED LOOPS
    5 4 NESTED LOOPS
    6 5 NESTED LOOPS
    9 6 TABLE ACCESS (FULL) OF 'TPARGESTIX'
    10 5 TABLE ACCESS (BY INDEX ROWID) OF 'TPARCPTTIX'
    11 10 INDEX (RANGE SCAN) OF 'IPARCPTTIX2' (NON-UNIQU
    E)
    12 4 TABLE ACCESS (BY INDEX ROWID) OF 'TPARGESTIX'
    13 12 INDEX (RANGE SCAN) OF 'IPARGESTIX1' (UNIQUE)
    14 3 INDEX (RANGE SCAN) OF 'PK_TTRALNKTIX' (UNIQUE)
    15 2 TABLE ACCESS (BY INDEX ROWID) OF 'TPARCPTTIX'
    16 15 INDEX (RANGE SCAN) OF 'IPARCPTTIX1' (UNIQUE)
    17 1 TABLE ACCESS (BY INDEX ROWID) OF 'TPTFBDR'
    18 17 INDEX (UNIQUE SCAN) OF 'IPTFBDR1' (UNIQUE)
    Statistics
    0 recursive calls
    5 db block gets
    11400369 consistent gets
    0 physical reads
    0 redo size
    1292 bytes sent via SQL*Net to client
    0 sorts (memory)
    0 sorts (disk)
    5 rows processed
    How can i tune this query ?
    why is the plan getting changed ?
    Hrishy
    Dec 2002
    Bangalore ( India )
    Hrishy ;
    Try this....i am not sure....coz never touched the performance manual yet...
    SQL> SELECT
    8 FROM ttralnktix,
    15 WHERE ( ( TPARCPTTIX_B.IDFTRA = TPARGESTIX_B.IDFTRA ) and
    16 ( TPARCPTTIX_A.IDFTRA = TPARGESTIX_A.IDFTRA ) and
    18 ( TPARCPTTIX_B.CODTRSPTF = TPTFBDR_B.CODTRS ) AND
    20 ( TPARCPTTIX_A.CODTRSPTF = TPTFBDR_A.CODTRS ) AND
    23 AND
    25 ;
    Abhay
    funky...
    New Delhi, INDIA
    Re: sql query tuning
    Hrishy
    The plan is changing because in the first querry you have used
    AND (tptfbdr_a.codptf = 'CROSB')
    and in the next
    AND (tptfbdr_b.codptf = 'WARTS')
    And because of this the access order of the table has changes as the table tptfbdr_b is some where at the bottom and tptfbdr_a is at the top in the from clause.
    Try using
    AND (tptfbdr_a.codptf = 'WARTS')
    and see whats the plan.
    Amar
    Amar's Blog  Get Firefox!
    Amar and Abhay..well with two geniuses at work..that query tuning problem seemed very very easy..if you are in bangalore india..then i would like to host a treat in honour of you guys :-)
    Hrishy
    Dec 2002
    Bangalore ( India )
    Hrishy
    am waiting for ur treat....coz am in bangalore india :-)
    funky...
    Dec 2002
    Bangalore ( India )
    Re: Re: sql query tuning
    and in the next
    Not Necessarly it should change.
    funky...
    Jan 2000
    Chester, England.
    Can someone please verify the 'best' order for tables in the FROM clause?
    Is it tables that would return LEAST number of rows (given the inidividual query) that should be last.
    Or is it smallest tables (whatever the query) that should be last?
    Also - In the WHERE clause should the most restrictive statement be last?
    Dec 2002
    Bangalore ( India )
    Order of table may not matter ... not sure
    Order of columns in where clause wud matter some times...
    it wud be best if most restrictive column is preceded before any columns...(though it wud go for toss if not indexed col)
    The order in which columns are indexes...if used in where clause in same order wud have beter performance ( i blv )..
    if i am wrong please bark at me...
    Abhay.
    funky...
    Solved thsi by creating a index on ttralnktix.NUMTRAFRTLNK
    1 0 NESTED LOOPS
    2 1 NESTED LOOPS
    3 2 NESTED LOOPS
    4 3 NESTED LOOPS
    5 4 NESTED LOOPS
    6 5 NESTED LOOPS
    QUE)
    13 4 TABLE ACCESS (BY INDEX ROWID) OF 'TTRALNKTIX'
    14 13 INDEX (RANGE SCAN) OF 'I_NUMTRAFRTLNK' (NON-UNIQ
    UE)
    15 3 TABLE ACCESS (BY INDEX ROWID) OF 'TPARGESTIX'
    16 15 INDEX (RANGE SCAN) OF 'IPARGESTIX2' (NON-UNIQUE)
    17 2 TABLE ACCESS (BY INDEX ROWID) OF 'TPARCPTTIX'
    18 17 INDEX (RANGE SCAN) OF 'IPARCPTTIX1' (UNIQUE)
    19 1 TABLE ACCESS (BY INDEX ROWID) OF 'TPTFBDR'
    20 19 INDEX (UNIQUE SCAN) OF 'IPTFBDR1' (UNIQUE)
    Statistics
    0 recursive calls
    0 db block gets
    1050 consistent gets
    0 physical reads
    136 redo size
    1398 bytes sent via SQL*Net to client
    0 sorts (memory)
    0 sorts (disk)
    6 rows processed
    so abhay you still win the treat i guess :-)
    Hrishy
    New Delhi, INDIA
    Re: Re: Re: sql query tuning
    In most of the cases the plan won't change, but if you are using ordered hint it would.
    Amar
