Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. #31
    Jan 2002
    SVRMGR> SELECT STATUS FROM DBA_ROLLBACK_SEGS
    2> WHERE SEGMENT_NAME = 'rbs01';
    STATUS
    0 rows selected.
  2. #32
    Jun 2001
    Helsinki. Finland
    Check Note:28812.1.
    It might solve the problem.
    P.S.: IMHO you should not have run that ABORT statement
    Oracle Certified Master
    email: ocp_9i@yahoo.com
  3. #33
    Jan 2002
    I've read the the doc on Metalink. I think I am just going to restore all the database files from my backup tape, which is going to take forever. Hope and pray that the database comes back up.
    Alter database using backup controlfile until cancel;
    And see what happens?
    What do you think?
  4. #34
    Jun 2001
    Helsinki. Finland
    What do you think?
    That's one way to go ahead. I would have set event = "10015 trace name context forever, level 10" in order to see what object Oracle is trying to apply the undo to, i.e, why it needs the RBS(s). Then droping the object(s) will help reuse the RBS(s) because the undo will be released. But it depends on what objects we are taling about.
