URGENT: ORA-01092: ORACLE instance terminated. Disconnection forced - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: URGENT: ORA-01092: ORACLE instance terminated. Disconnection forced
  1. #21
    Jan 2002
    And to answer your previous question the Tablespace name is RBS
    checked 1 of my logs now....
  2. #22
    Jun 2001
    Helsinki. Finland
    Could you take all RBSs online?
    Could you drop the ones that you could not?
    Oracle Certified Master
    Oracle Certified Professional 6i,8i,9i,10g,11g
    email: ocp_9i@yahoo.com
  3. #23
    Jan 2002
    Julian, this is what I get when I try to put the online.
    It says it's online and when i try to take it offline it says it is not online.
    SVRMGR> alter ROLLBACK SEGMENT rbs02 ONLINE;
    ORA-01636: rollback segment 'RBS02' is already online
    SVRMGR> alter ROLLBACK SEGMENT rbs02 OFFLINE;
    ORA-01598: rollback segment 'RBS02' is not online
  4. #24
    Jun 2001
    Helsinki. Finland
    That's good. Are they all online? All RBSs?
    If so, no worries!
  5. #25
    Jan 2002
    Just check the previous error I sent to you. The 1st staement says , it is ONLINE
    and the 2nd statement says that it is NOT online.
    It is confused.
  6. #26
    Jun 2001
    Helsinki. Finland
    It is confused.
    I just noticed that. Bugger ...
    Are you able to drop it?
  7. #27
    Jan 2002
    No , I was not able to drop the RBS. :(
    SVRMGR> DROP ROLLBACK SEGMENT rbs01;
    ORA-01545: rollback segment 'RBS01' specified not available
  8. #28
    Jun 2001
    Helsinki. Finland
    Try firs this:
    Off-line and bring back on-line all the user tablespaces.
    Once this is done, the problem rollback segments status will change to on-line.
    Then do shutdown immediate on the database and startup.
    You will then be able to drop this rollback segment.
    If this does not work you may try this but using the undocumented parameters is not that good:
    insert the following line in the INIT.ORA:
    _corrupted_rollback_segments=(RBS01,RBS02)
    You may add all other ones.
    1. bounce tha database
    2. drop the RBSs
  9. #29
    Jan 2002
    Do I have to bring down and up all the other user tablespaces?
    This user has +/- 100 tablespaces, it is a Oracle Financials Database.
    And the _corrupted_rollback_segments=(RBS01,RBS02)
    I read in metalink that this could be dangerous......
    I am not starting to feel well.
  10. #30
    Jun 2001
    Helsinki. Finland
    Yes, all tablespaces. Don't start doing that then...
    And yes, setting _corrupted_rollback_segments=(RBS01,RBS02) might be dangerous because you might have there a non-rollbacked data dictionary transaction. Don't do that either.
    Bad situation...
    Open iTar with Metalink.
    What is the status of the rollback segments?
