    Apr 2002
    Exception Handling
    The following code is returning an error
    create or replace procedure sk_test
    as
    v_sk number(3);
    v_errm varchar2(100);
    select 5/0 into v_sk from dual;
    insert into sk values(v_sk);
    commit;
    exception
    when zero_divide then
    v_sk:=0;
    SELECT 5/1 into v_sk from user_objects ;
    exception
    when too_many_rows then
    insert into sk values(0);
    oommit;
    end;
    end;
    ORA-06502: PL/SQL: numeric or value error: character string buffer too small
    ORA-06512: at "REBOOKER.SK_TEST", line 16
    ORA-01422: exact fetch returns more than requested number of rows
    ORA-01476: divisor is equal to zero
    ORA-06512: at line 1
    The code within the second exception is not executed.Can I have a method wherein the code with the second exception is executed.
    Thanks is advance
    Reading, U.K
    hi this is wht i did and worked fine:
    just try increasing the size of variable and check the table structure (column size)
    v_sk number(3);
    19:18:46 SQL> create table sk(a number);
    Table created.
    Elapsed: 00:00:00.02
    19:18:57 SQL> create or replace procedure sk_test
    19:19:09 2 as
    19:19:09 3 v_sk number(3);
    19:19:09 4 v_errm varchar2(100);
    19:19:09 5 begin
    19:19:09 6 select 5/0 into v_sk from dual;
    19:19:09 7 insert into sk values(v_sk);
    19:19:09 8 commit;
    19:19:09 9 exception
    19:19:09 10 when zero_divide then
    19:19:09 11 begin
    19:19:09 12 v_sk:=0;
    19:19:09 13 SELECT 5/1 into v_sk from user_objects ;
    19:19:09 14 exception
    19:19:09 15 when too_many_rows then
    19:19:09 16 insert into sk values(0);
    19:19:09 17 oommit;
    19:19:09 18 end;
    19:19:09 19 end;
    19:19:09 20 .
    19:19:11 SQL> ed
    Wrote file afiedt.buf
    1 create or replace procedure sk_test
    2 as
    3 v_sk number(3);
    5 begin
    8 commit;
    9 exception
    11 begin
    12 v_sk:=0;
    14 exception
    17 commit;
    18 end;
    19* end;
    19:19:18 SQL> /
    Procedure created.
    Elapsed: 00:00:00.03
    19:19:18 SQL> exec sk_test
    Elapsed: 00:00:00.00
    19:19:32 SQL> select * from sk;
    A
    0
    Cheers!
    OraKid.
    Reading, U.K
    check the spelling commit. its "oommit;" in ur code
    Cheers!
    OraKid.
