First, create some tablespaces:
SQL> create tablespace dmt datafile 'd:\oracle\oradata\nt817\dmt01.dbf'
2 size 10M autoextend on next 10M maxsize 1000M
3 default storage (pctincrease 0);
Tablespace created.
SQL> create tablespace lmt datafile 'd:\oracle\oradata\nt817\lmt01.dbf'
3 extent management local;
Tablespace created.
Next, create some tables:
SQL> create table my_dmt_tab (x number(10),
2 y number(10),
3 z number(10))
4 tablespace dmt
5 storage (minextents 129);
Table created.
SQL> create table my_lmt_tab (x number(10),
2 y number(10),
3 z number(10))
4 tablespace lmt
Table created.
Now, you would expect the tables to be the same size, right?
SQL> col segment_name for a20
SQL> col mb for 999999999.00
SQL> select segment_name, sum(bytes/1024/1024) mb
2 from dba_segments
3 where segment_name like 'MY%'
4 group by segment_name
5 /
SEGMENT_NAME MB
MY_DMT_TAB 5.04
MY_LMT_TAB 129.00
Hmmm, that's odd. Wonder what's happening here?
1 select segment_name, blocks, count(*)
2 from dba_extents
4 group by segment_name, blocks
5* order by segment_name, blocks
SQL> /
SEGMENT_NAME BLOCKS COUNT(*)
MY_DMT_TAB 5 129
MY_LMT_TAB 128 49
MY_LMT_TAB 1024 10
Ah ha. While the DMT tablespace had all 129 extents as the same extent size (because my pctincrease was 0), the AUTOALLOCATE LMT only had 59 extents but some were 1024 blocks and some were 128 blocks.
