    I have a problem with integrity constraints. I have a table with two columns:
    CREATE TABLE Constraint_Demo
    (Item_1 VARCHAR2(10),
    Item_2 NUMBER(10),
    CONSTRAINT Tuple_Check CHECK ((Item_1 = 'A' AND Item_2 != Null) OR (Item_1 = 'B' AND Item_2 = Null))
    If 'A' is inserted in the first column, then a number must be inserted in the second column. On the other hand, if 'B' is inserted in the first column, there must be inserted NULL in the second column. Example:
    Item_1 | Item_2
    A | 1 --> ok
    B | NULL --> ok
    A | NULL --> Not allowed!
    B | 1 --> Not allowed!
    However, the following statements are ok:
    insert into Constraint_Demo values ('A', NULL);
    insert into Constraint_Demo values ('', 1);
    Why? And what is the correct syntax?
    Dan
    Jul 2000
    With NULL don't use '= NULL' or '!= NULL', but use 'IS NULL' or 'IS NOT NULL'. Check item_1 is not null.
    Comparisons involving nulls always yield NULL , OR returns TRUE only if either one of the operands is TRUE, AND returns TRUE only if both operands are true.
    (Item_1 VARCHAR2(10) NOT NULL,
    Item_2 NUMBER(10),
    CONSTRAINT Tuple_Check CHECK ((Item_1 = 'A' AND Item_2 IS NOT Null) OR (Item_1 = 'B' AND Item_2 IS Null))
    Hi akkerend,
    thanks for the hint! It works perfectly like this!
    Dan
