Results 1 to 8 of 8
    Chicago IL
    Pls help me analyze tkprof output
    Please help me analyze this TKPROF output
    thanks
    Jigar
    Attached Files Attached Files
    "High Salaries = Happiness = Project Success."
    greenwich.ct.us
    The problem is it's a 26 table outer join. I suspect you should be happy with only 2 minutes of query time...
    I'd nominate this query for Fox's new special "When Bad SQL Attacks..."
    marist89@yahoo.com
    http://marist89.blogspot.com/
    Get Firefox!
    Sep 2001
    NJ, USA
    Yep. Probably this is record number of sort-merge loops,
    that i have seen.
    Chicago IL
    Shetakov and Marist
    thanks for the responses. I realize that there are 26 table outerjoins.unfortunately this query is generated by Crystal Reports. Monday, we have a call with the vendor who wrote this query. Can you please give me suggestions on what to tell the vendor - as far as what type of changes they need to make?
    I am also including my report.txt as well.
    greenwich.ct.us
    It's simple, the query needs to change. I haven't the slightest idea HOW the query should change because I don't know anything about the application.
    marist89@yahoo.com
    Get Firefox!
    Chicago IL
    Marist,
    can you pls look at the report.txt and see everything is ok and if you can make recomendations?
    thanks
    Jigar
    Feb 2003
    jigarlakhani
    Occupation: Senior Oracle DBA
    Interests: Solaris, HP, Performance Tuning
    what kind of senior you are lol
    Sep 2001
    NJ, USA
    Jeff had said to u :
    U have to change select statment.
    Statspack report cannot solve this problem at all.
