Changing Date and Time
Thread: Changing Date and Time
    Feb 2003
    Tehran/Iran
    Hi all,
    Suppose of some reason you would like to change the time oracle database,
    1. Do you know how to change the and time of database.
    2. And how to change the format of sysdate reporting Hard code in the database. You can use:
    select to_char(sysdate, 'YYYY-MM-DD hh:min:ss') from sysdate;
    How can change the time format of database to get the time of database as the answer to above query from sysdate.
    Thanks Hamid
    Washington DC
    Oracle Server time depends on OS time.Change us OS time.
    Default, is DD-MON-YY
    U can change like as follows
    Alter session set nls_data_format='dd/mm/yyyy';(or the avialable date formats in oracle)
    Feb 2003
    Tehran/Iran
    Thanks for the answer. Do you know how to change permanently for the hole database not for the session.
    Regards Hamid
    You can set that in the init.ora file
    Hrishy
    Washington DC
    Update the value of nls_date_format in init.ora and restart the database
