Results 1 to 8 of 8
    New Delhi, INDIA
    How to and when to recreate control files.
    Q. When to create control files ?
    A. Create controlfiles when
    1. You have lost all your control files.
    2. When you want to rename a database name (db_name)
    Q. How to create control files.
    You need a create controlfile script for recreating control files.
    SQL*Plus: Release 9.2.0.2.0 - Production on Fri Feb 28 17:04:00 2003
    Copyright (c) 1982, 2002, Oracle Corporation.  All rights reserved.
    Enter user-name: sys as sysdba
    Enter password:
    Connected to:
    Oracle9i Enterprise Edition Release 9.2.0.2.1 - Production
    With the Partitioning, Oracle Label Security, OLAP and Oracle Data Mining options
    JServer Release 9.2.0.2.0 - Production
    SQL> alter database backup controlfile to trace;
    Database altered.
    SQL>
    This will create a trace file in the udump directory.
    Im my case it was
    E:\oracle\admin\ORCL\udump\orcl_ora_2052.trc
    Edit the file to point the path of the datafiles and redologfiles.
    CREATE CONTROLFILE REUSE DATABASE "ORCL" RESETLOGS  ARCHIVELOG
        MAXLOGFILES 5
        MAXLOGMEMBERS 3
        MAXDATAFILES 14
        MAXINSTANCES 1
        MAXLOGHISTORY 226
    LOGFILE
      GROUP 1 'E:\ORACLE\ORADATA\ORCL\REDO01.LOG'  SIZE 100M,
      GROUP 2 'E:\ORACLE\ORADATA\ORCL\REDO02.LOG'  SIZE 100M,
      GROUP 3 'E:\ORACLE\ORADATA\ORCL\REDO03.LOG'  SIZE 100M
    DATAFILE
      'E:\ORACLE\ORADATA\ORCL\SYSTEM01.DBF',
      'E:\ORACLE\ORADATA\ORCL\UNDOTBS01.DBF',
      'E:\ORACLE\ORADATA\ORCL\EXAMPLE01.DBF',
      'E:\ORACLE\ORADATA\ORCL\INDX01.DBF',
      'E:\ORACLE\ORADATA\ORCL\TOOLS01.DBF',
      'E:\ORACLE\ORADATA\ORCL\USERS01.DBF',
      'E:\ORACLE\ORADATA\ORCL\OEM_REPOSITORY.DBF',
      'E:\ORACLE\ORADATA\ORCL\CWMLITE01.DBF',
      'E:\ORACLE\ORADATA\ORCL\DRSYS01.DBF',
      'E:\ORACLE\ORADATA\ORCL\ODM01.DBF',
      'E:\ORACLE\ORADATA\ORCL\XDB01.DBF',
      'E:\ORACLE\ORADATA\ORCL\USERS02.DBF',
      'E:\ORACLE\ORADATA\ORCL\USERS03.DBF',
      'E:\ORACLE\ORADATA\ORCL\USERS04.DBF'
    CHARACTER SET WE8MSWIN1252
    ALTER DATABASE OPEN RESETLOGS;
    and rename it to ctl.sql
    Then startup the database in nomount mode and run the ctl.sql file as sys as sysdba user
    SQL*Plus: Release 9.2.0.2.0 - Production on Fri Feb 28 17:25:14 2003
    Enter password:
    Connected to an idle instance.
    SQL> startup nomount
    ORACLE instance started.
    Total System Global Area   80812648 bytes
    Fixed Size                   453224 bytes
    Variable Size              54525952 bytes
    Database Buffers           25165824 bytes
    Redo Buffers                 667648 bytes
    SQL> @E:\oracle\admin\ORCL\udump\ctl.sql
    Control file created.
    Database altered.
    SQL> select status from v$instance;
    STATUS
    OPEN
    SQL> select name from v$controlfile;
    NAME
    E:\ORACLE\ORADATA\ORCL\CONTROL01.CTL
    E:\ORACLE\ORADATA\ORCL\CONTROL02.CTL
    E:\ORACLE\ORADATA\ORCL\CONTROL03.CTL
    To rename the database change reuse to set in the create control file script as shown below
    CREATE CONTROLFILE SET DATABASE "ORCL" RESETLOGS  ARCHIVELOG
        MAXLOGFILES 5
        MAXLOGMEMBERS 3
        MAXDATAFILES 14
        MAXINSTANCES 1
        MAXLOGHISTORY 226
    LOGFILE
    DATAFILE
    HTH
    Amar
    Amar's Blog  Get Firefox!
    Geneva Switzerland
    Good stuff Amar!
    Perhaps you should point out that "alter database backup controlfile to trace;" needs to be done BEFORE you loose the control files!
    "The power of instruction is seldom of much efficacy except in those happy dispositions where it is almost superfluous" - Gibbon, quoted by R.P.Feynman
    New Delhi, INDIA
    Originally posted by DaPi
    Good stuff Amar!
    Please note that
    Amar
    Feb 2013
    Dear ,
    if you have lost all control files then do the following.
    1. create new database using dbca on the same database server version.
    2. create control file script as above.
    3. Move new data files to some other place and copy old data files of your database on the new server.
    4. Modify control file script so that it points to copied data files (Add all data files path).
    5. now create new control file with the modified control file script.
    6. Recover your database.(see database recovery process).
    Apr 2015
    Hi, your post is something new to me and helpful. Anyway, upon a thorough search about the topic , I found out that the first control files of an oracle database are created when you issue the create database statement. On the other side, we are able to manually create a new control file for a database using the create control file statement. This is the reason why control file is recreated. I just hope, I make sense with this
    Aug 2017
    What about the db references in the spfile when you want to rename the db? When running the create controlfile command I got this error:
    ORA-01503: CREATE CONTROLFILE failed
    ORA-01504: database name 'FOO1' does not match parameter db_name 'foo'
    I created pfile from spfile, changed all db references there, and converted back to spfile.
    Then it worked!
    Somehow offtopic, but also edit name in /etc/oratab to reflect name change for dbca.
    i'm using Adewri's code as an example. Instead of the word reuse, you need to use the word "SET".
    Keep in mind that the Oracle database has changed significantly in the last 14 years. The original
    post was written for 7.3.4, 8.0 or 8i. Few people used RMAN back when this post was written.
    Now, you can restore the control file and use the nid program to change the database name.
    Therefore you don't specifically need to recreate the control files. Is there a specific problem
    that you are trying to solve?
        MAXLOGFILES 5
        MAXLOGMEMBERS 3
        MAXDATAFILES 14
        MAXINSTANCES 1
        MAXLOGHISTORY 226
    LOGFILE
    DATAFILE
    CHARACTER SET WE8MSWIN1252;
    Aug 2017
    I'm learning about the CloneDB feature using copy on write with Direct NFS introduced in Oracle 11. In a first step you need to create a db clone and creating a cold backup plus creating controlfile is one method often described. I know it might not be the latest preferred method, but I'm still learning to understand what's going on under the hood.
