Hello,
I am getting an error while pinning a pl/sql block using dbms_shared_pool
Where I am going wrong? Is it possibe to load sql statement which is not in a pl/sql block or not in a funcion or procedure using the statement address and hash value? I get the same error if I try to pin a statement. I am able to pin procedure or function.Code:SQL> l 1 select sql_text, address, hash_value from v$sqlarea 2* order by first_load_time desc SQL> SQL_TEXT ADDRESS HASH_VALUE -------------------------------------------------------------------------------------- declare ss varchar2(100); cursor c1 is select object_name 036FD9C0 2702567367 from all_objects where object_type like 'PROC%'; begin open c1; loop fetch c1 into ss; exit when c1%notfound; end loop; close c1; end; SQL> exec dbms_shared_pool.keep('036FD9C0,2702567367'); BEGIN dbms_shared_pool.keep('036FD9C0,2702567367'); END; * ERROR at line 1: ORA-00931: missing identifier ORA-06512: at "SYS.DBMS_UTILITY", line 68 ORA-06512: at "SYS.DBMS_SHARED_POOL", line 45 ORA-06512: at "SYS.DBMS_SHARED_POOL", line 53 ORA-06512: at line 1
Please advice
Sameer
