    problem with listener
    hi,
    I've installed oracle 8.1.7 server with two istance
    IMM1
    IMM2
    IMM2 run correctly, but when I started IMM1 I get this error:
    ORA-12541:TNS:NO LISTENER
    the listener is up (status listener is OK)
    this is the file listener.ora:
    IMM2 =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = srvimm)(PORT = 1521))
    (CONNECT_DATA =
    (SERVICE_NAME = imm2)
    IMM1 =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (CONNECT_DATA =
    (SERVICE_NAME = imm1)
    tnsping imm1 run correctly
    How can I started imm1???
    Raf
    Dec 2001
    Atlanta
    Hi Raf,
    Make sure the tnsname.ora file is also under network/admin folder of the directory in which imm1 is located.
    C. K.
    AppsDBA 11i
    CA USA
    Is it OK to have same port no for two instances? From your listner.ora file HOST is same and even PORT no is also same.. Is it ok?? I think you need to change the port no and then try...
    Cheers !!
    Harshal
    Well, for one, that is not your listener.ora file. What you pasted in was all or part of your tnsnames.ora file.
    The listener.ora file looks like this:
    LISTENER =
    (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = stecalpc)(PORT = 1521))
    SID_LIST_LISTENER =
    (SID_LIST =
    (SID_DESC =
    (GLOBAL_DBNAME = db00)
    (ORACLE_HOME = d:\oracle\ora81)
    (SID_NAME = db00)
    (SID_DESC =
    (GLOBAL_DBNAME = cendb)
    (SID_NAME = cendb)
    Make sure your SID is listed in the listener.ora file. You can have a gazillion SIDs listed for the listener on port 1521. If your listener was okay, you would have seen both instances registered, so what did you mean by "the listener is up (status listener is OK)?"
