Is there a way to use Indirect Variable Referencing in a Trigger?
Thread: Is there a way to use Indirect Variable Referencing in a Trigger?
    I wish to write a trigger that can be used on multiple tables to can dynamically output all data values in
    the record through reading of the system catalog tables. The main problem that I have encountered is
    that the column names such as :NEW.CUST_ID need to be known at compile time. I wish to build a string
    which contains ':NEW.CUST_ID' and have it return the contents of :NEW.CUST_ID.
    Jul 2000
    Use dynamic SQL.
    But then a single trigger can not be used for multiple table.
    svk
