Thread: sql trigger to oracle trigger
    Oct 2002
    i have a code in sql and wants to do the same kind of thing in oracle,can anybody help me,
    CREATE TRIGGER tIU_tblSecApplicationUsers ON dbo.tblSecApplicationUsers
    FOR INSERT, UPDATE
    AS
    RETURN
    DECLARE @UserID INT
    DECLARE @LoginID VARCHAR(25)
    DECLARE @FirstName VARCHAR(25)
    DECLARE @MiddleName VARCHAR(25)
    DECLARE @LastName VARCHAR(25)
    SELECT @UserID = UserID, @LoginID = AppUserName, @FirstName = FirstName, @MiddleName = MiddleName, @LastName = LastName FROM INSERTED
    IF UPDATE(AppUserName) OR UPDATE(FirstName) OR UPDATE(MiddleName) OR UPDATE(LastName)
    IF EXISTS (SELECT * FROM Users WHERE UserID = @UserID)
    UPDATE Users SET
    LogonID = @LoginID,
    FirstName = @FirstName,
    MiddleName = @MiddleName,
    LastName = @MiddleName
    WHERE UserID =@UserID
    END
    ELSE
    INSERT INTO Users (
    LogonID,
    FirstName,
    MiddleName,
    LastName,
    UserID
    VALUES (
    @LoginID,
    @FirstName,
    @MiddleName,
    @LastName,
    @UserID
    UPDATE users SET UserId = @UserID WHERE LogonID = @loginID
    END
    END
    especially how to check 'if exists' kind of thing in oracle and 'from inserted'.
    please help me
    Apr 2002
    Philippines
    sneha,
    For the "if exists" you could try the when no_data_found exception:
    SELECT *
    FROM Users
    WHERE UserID = @UserID;
    ... -- update codes here
    EXCEPTION
    WHEN NO_DATA_FOUND THEN
    ... -- insert codes here
    For "from inserted" you can use the :NEW qualifier like :NEW.UserID, :NEW.AppUserName, :NEW.FirstName, etc. You would assign the variables to this values.
    Check the Oracle Docs for more info on triggers.
    hth.
