Importing Tables Using MS Access-PROBLEM
Thread: Importing Tables Using MS Access-PROBLEM
    hi,
    I have connected to APPS DB through ODBC in Access but i am not getting all the tables ,it is showing only one table i changed ODBC versions but invain.
    MS ACCESS 97 , DATABASE-Oracle8i Enterprise Edition Release 8.1.7.2.0 - 64bit Production
    Pl suggest me some solution.
    goradba
    Jan 2002
    Netherlands
    change the row set to 100 and on the Oracle ODBC 32bit test GUI keep punching next row to get the other tables, you can also check out hte user tabls(the ones you made on that schema)
    Tarry Singh
    I'm a JOLE(JavaOracleLinuxEnthusiast)
    TarryBlogging
    --- Everything was meant to be---
    Thanks Tarry ,
    I didn't get
    {on the Oracle ODBC 32bit test GUI keep punching next row to get the other tables.)
    How can i do that.
    I have tried all other options but no use.
    Thanks,Regards
    goradba
