    Hi all,
    If in SQL 7.3 I lock a table using the folwoing command:
    lock table tmp_problem_file in share mode nowait;
    Then how to unlock?????
    Thanks and Regards
    By executing either COMMIT or ROLLBACK.
    Thank you very much...
    However, suppose that I do COMMIT then I decide to unlock the table what should I do?
    USA
    may be u can try
    alter system kill session 'sid, serial#';
    following query shows which table has been locked in what mode , u will get sid and serial # also from this .
    select nvl(S.USERNAME,'Internal') username, nvl(S.TERMINAL,'None') terminal, L.SID||','||S.SERIAL# Kill, U1.NAME||'.'||substr(T1.NAME,1,20) tab,
    decode(L.LMODE,1,'No Lock', 2,'Row Share', 3,'Row Exclusive', 4,'Share', 5,'Share Row Exclusive', 6,'Exclusive',null) lmode,
    decode(L.REQUEST,1,'No Lock', 2,'Row Share', 3,'Row Exclusive',4,'Share', 5,'Share Row Exclusive', 6,'Exclusive',null) request from V$LOCK L, V$SESSION S, SYS.USER$ U1, SYS.OBJ$ T1 whereL.SID = S.SID and T1.OBJ# = decode(L.ID2,0,L.ID1,L.ID2) and U1.USER# = T1.OWNER# and S.TYPE != 'BACKGROUND' order by 1,2,5
    [Edited by prakashs43 on 10-02-2002 at 08:23 AM]
    siva prakash
    DBA
    Once you do COMMIT all your locks are released, so the table is no longer locked. So you can't "decide to unlock the table", it is already unlocked.
    You can never explicitely unlock the tables you have locked - it can be done only implicitly by COMMIT or ROLLBACK. There is no third way.
    Thumbs up
    THANK YOU ALL FOR YOUR VALUABLE HELP!!!
