Originally posted by sumit
Hi Nagesh
Is your problem solved? Let me know. I hope I can give u the solution.
Sumit
No. Not Yet. You can shed some light on this.
Thanks In Advance.
Nagesh
Hi Guru's
Still I am stucked up with this problem. I had set
NLS_LANG=AMERICAN_AMERICA.UTF8, and the problem still exists. Please Help.. When I use sqlplus to select the data "????" are appeariing.
Thanks In Advance.
Nagesh
Hi ,
What is the CHARACTER SET of the database where from the export has been taken?
And what is the character set of ur current database ?
Tell me that first. Then I will tell u what to do next.
Sumit
sumit
Hello
I hope , the O/S in ur export server is different than import server.
U r using Solaris Server. Right? But do u know what is the O/S? is it Chinese ?
For example if my export server is JAPANESE O/S and my local database is english O/S then you will face this type of problem.
Is that same? or different as I mentioned.
Sumit
sumit
Thank You Summit.
Basically I am using SunOs Server. My Source(EXP) and target (IMP) database's are on the same BOX. And My NLS_CHARCTER_SET is UTF8.
I hope this information helps you to analyze the problem.
Thanks In Advance.
Nagesh
Still I am seeking your help. Please Help me.
Thanks In Advance.
Nagesh
I get export from a database with Japanese char set. Just before doing the import, I do:
export NLS_LANG="AMERICAN_AMERICA.JA16SJIS"
Try all these possibilities. Check ur export log file and see what is specified before doing the export.
I did but I exported NLS_LANG=AMERICAN_AMERICA.UTF8, not with "". Is it wrong?
Thanks In Advance
Nagesh
I dont know what significance "" has in this case. Y dont u try it and see.
My understanding is:
1) you made dump file of UTF8 database with NLS_LANG= ...
UTF8
2) you loaded dump file to UTF8 database with NLSLANG= ... UTF8
3) then you tryed to make s select from the same Solaris Box and got ????.
That is correct result in that case.
Question:
1) Before making query did you change your NLS_LANG to be Chanese?
It must be the same character set Chinese records were created with.
2) Does your Solaris BOx has Chinese character set installed?
Best wishes!
Dmitri
