How to Tune DB_BLOCK_BUFFERS in 9i
Results 1 to 7 of 7
Thread: How to Tune DB_BLOCK_BUFFERS in 9i
    Jun 2002
    Dear Gurus,
    Just now i run the following query:
    SQL> select round ((1-(sum(decode(name,'physical reads',value,0)) /
    2 (sum(decode(name, 'db block gets',value,0)) +
    3 sum(decode(name, 'consistent gets',value,0))))) * 100, 4)
    4 hitratio
    5 from v$sysstat;
    HITRATIO
    76.6596
    Right now My database hitratio is 76.65. But oracle recommonded hit ratio above 90%.
    My Database Buffres(db_cache_size) is 67108864 (Oracle9i Solaris Platform)
    How to tune Database Buffers?
    Please advise me, Thanks in advance,
    Iyyappan.M
    Jun 2001
    Helsinki. Finland
    Increase the buffers.
    Oracle Certified Master
    Oracle Certified Professional 6i,8i,9i,10g,11g
    email: ocp_9i@yahoo.com
    go to http://www.hotsos.com and read
    Why 99% Database Buffer Cache Hit Ratio is NOT Ok by Cary Millsap
    Jun 2001
    Helsinki. Finland
    Was this about the company in Copenhagen, bla-bla-bla :-)) Come on David, you don't really trust that bull****, do you :-)
    [Edited by julian on 08-24-2002 at 10:57 AM]
    Jun 2002
    Tuning DB_BLOCK_BUFFERS IN 9i
    My DB_BLOCK_BUFFERS value is
    select state,count(*)
    from x$bh
    group by state;
    state Count(*)
    0 274
    1 7642
    3 40
    Total DB_BLOCK_BUFFERS = 7956(274+7642+40)
    My question is how much value i have to put or increase?
    Can u please explain,
    Awaiting ur reply,
    Thanks in advance,
    Iyyappan.M
    Jun 2001
    Helsinki. Finland
    Re: Tuning DB_BLOCK_BUFFERS IN 9i
    For a start, increase the value by 10%.
    Dec 2001
    UK
    Start Oracle Enterprise Manager and use the buffer cache advisory to check the effect of adding/removing memory to/from the buffer cache. If adding memory has no significant effect on the ratio why waste it!
    Remember, hit ratios are a very basic way of tuning a system. You should consider looking at the YAPP method. Basically this involves eliminating/reducing wait states rather than focusing on hit ratios:
    http://www.oracle-base.com/Articles/8i/Statspack8i.asp
    http://www.oracle-base.com/Links/yapp_anjo_kolk.pdf
    http://www.oracle-base.com/Links/oraperf_bw.pdf
    Cheers
    Tim...
    OCP DBA 7.3, 8, 8i, 9i, 10g, 11g
    OCA PL/SQL Developer
    Oracle ACE Director
    My website: www.oracle-base.com
    My blog: www.oracle-base.com/blog
