    Shanghai
    Is there any utility can be used to perform the job ?
    1. www.dbasupport.com
    2. www.dbforums.com
    3. www.itpub.net
    4. www.csdn.net
    5. www.umlchina.com
    6. www.tek-tips.com
    7. www.cnforyou.com
    8. fm365.federal.com.cn
    9. www.programmersheaven.com
    10.http://msdn.microsoft.com/library/default.asp
    ligang1000@hotmail.com
    Oct 2001
    I have used Transformation Server from DataMirror. It is easy to use. Check this URL:
    http://www.datamirror.com/products/tserver/
    Cheers
    Angel
    You can use SELECT/INSERT or other types of Heterogeneous Replication with Oracle Transparent Gateway and Generic Connectivity.
    See Oracle manual for Heterogeneous Connectivity.
    Regards.
