hi,
When i was trying to install oracle8i on solarsis 2.8(sparc), the linking failed,
throwing an error.. make utility not found.
What is this make utility all about and why is this required. If it is not present by default on solaris, how to install it
Can any body put some light on this.
sonia
make sure you have
/usr/ccs/bin
in your path. If you have /usr/ucb/bin in your path make sure this comes _after_ /usr/ccs/bin.
Andrew
Also make sure that you set the environment variable LD_LIBRARY_PATH
Refer to the installation docs to make sure you are setting all the required environment variables and PATH.
HTH
Sanjay
yehh......path and all has been set to /usr/ccs/bin...
but the make file is missing inside the bin direcotry...
probably some one might have deleted that...
could any body guide what this make file contains......
Hello Sonia
The problem is becuase make is not installed on your computer and you are unable to relink the oracle excutables.Please go to sun website or as your system administrator to install the make utility.
without installing the make utility you cannot install oracle.
Hrishy
thanx hrishy,
My sys admin is not a unix person, i have to manage myself.
What if i copy the make file of different system and put it in /usr/ccs/bin ?..do u think it works....
well what this make file is all about...
could u brief me abt it.
the makefile is a file that lists all of the other files (libaries, header files) that the oracle binary (and other programs) need to run. Instructions on how to "make" the oracle executable.
On Solaris if you go to $ORACLE_HOME/bin and run
ldd oracle
you will see all the dynamic libraries that oracle program is linked to.
If you have ever configured RMAN in Oracle 8.0.x to work with Veritas you have to create a link in $O_H/lib to Veritas's libobk.so file. then run
$O_H/rdbms/lib/make -f ins_rdbms.mk ioracle
after this is successful you can do a ldd oracle and see the new libobk.so file "linked" into the oracle executable. Now the oracle program can talk to the Veritas program through the libobk.so library.
hope this helps,
Andrew
thanx andrew,
the info really helped me
sonia
