RMAN backup script not running from cron
Results 1 to 9 of 9
Thread: RMAN backup script not running from cron
    Feb 2000
    Singapore
    Oracle 8.0.6
    Compaq Tru64 4.0D
    I am trying to RMAN backup job from cron.
    The shell script I wrote works fine when run interactively but doesn't work when scheduled through cron. The log file, to which I am directing the output of the shell comes blank.
    I suspect I am missing some environment variables but don't know which one? Below are my shell script and rman script.
    #backup_full_db.sh
    export ORABIN=/ora01/app/oracle/product/8.0.6/bin
    export PATH=.:/ora01/app/oracle/product/8.0.6/bin:/opt/bin:/bin:/usr/bin:/usr/ccs/bin:/usr/local/bin
    export ORACLE_BASE=/ora01/app/oracle
    export ORACLE_SID=fdbsp
    export LD_LIBRARY_PATH=/ora01/app/oracle/product/8.0.6/lib:/usr/lib
    export ORACLE_HOME=/ora01/app/oracle/product/8.0.6
    /ora01/app/oracle/product/8.0.6/bin/rman target sys/password@fdbsp rcvcat rman/rman@catlg cmdfile /ora01/app/oracle/cron/backup_ful
    l_db.rman msglog /ora01/app/oracle/cron/output/backup_full_db.log
    #backup_full_db.rman
    run {execute script backup_full_db_al_disk;}
    exit
    Any idea? Appreciate all help.
    Sanjay
    Apr 2002
    Germany.Laudenbach
    Wink
    Hi;
    Have you tried the script starting in background
    cmd &
    - When some errors occur cron writes a mail; have you checked this
    - you manually recreate the environment, would it be possible to execute the profiles in your script
    # Not forget the point-command ( exec in this shell )
    . /etc/profile
    . /u/...home/oracle/.profile # or .bash_profile
    to get the whole environment
    in cron you can explicit direct the stderr and stdout to disk
    cmd  > file.log 2> file.err
    Hope it helps
    Orca
    PS.: i would appreciate to work under TRUE64!
    Feb 2000
    Singapore
    Hi Orca, thanks for the response..
    - No mail generated. Checked it.
    - tried running .profile in the script. It also doesn't work.
    - i am explicitly dircting the cron output to a log file. That log file is generated but it is blank with size 0 bytes.
    I tried running the shell script interactively under root and it works. It only doesn't work when put in cron.
    Any other reason??
    Sanjay
    Apr 2002
    Germany.Laudenbach
    Send me please the output of
    crontab -l
    Orca
    Ireland/Dublin
    Try this
    Create crontab as ROOT and use:
    00 01 * * 0 su -l oracle --command="/home/oracle/script.sh"
    Best wishes!
    Dmitri
    Feb 2000
    Singapore
    excerpts from crontab for user oracle
    # RMAN job to backup full database to disk everyday.
    16 16 * * * /ora01/app/oracle/cron/backup_full_db.sh > /ora01/app/oracle/cron/output/backup_job.log
    Hi kgb, ideally the job should work under user oracle. Though I didn't try under root.
    Sanjay
    [Edited by SANJAY_G on 07-12-2002 at 05:24 AM]
    Apr 2002
    Germany.Laudenbach
    Sorry no idea !
    crons looks good
    Orca
    Apr 2002
    Germany.Laudenbach
    Look at this
    http://www.geocities.com/webdbaquest...an_backup.html
    In the backup-shell-script the first line specs the Shell for example.
    Orca
    Feb 2000
    Singapore
    A ha!!
    It works now. I have added the following line at the start of the shell script and it did the trick.
    #!/bin/ksh
    The environment variable defined in my script were not getting executed because they were defined in korn shell format and by default the cron uses some other shell.
    Thanks all for the response.
    Sanjay
