function based index problem
Results 1 to 9 of 9
Thread: function based index problem
    I created a function based index by using:
    create unique index UQ_TABLE1_NAME on TABLE1 ( upper(NAME) );
    Then tried to run a simple query with SQLPLUS:
    SELECT * FROM table1 WHERE UPPER(name) LIKE UPPER('%abcd%') ORDER BY UPPER(name);
    I got a error:
    ORA-03113: end-of-file on communication channel
    The strange thing is running "SELECT * FROM table1 WHERE name LIKE UPPER('%abcd%') ORDER BY UPPER(name)" or "SELECT * FROM table1 WHERE UPPER(name) LIKE UPPER('%abcd%') ORDER BY name" OK. I also removed the index and re_created it, then the problem disappeared.
    Does any one konw how this happens.
    zm
    when checked the dump trace file, found :
    ORA-07445: exception encountered: core dump [evaopn2()+1104] [SIGSEGV] [Address not mapped to object] [0x0] [] []
    zm
    Aug 2001
    chennai,bangalore
    Did u retry the same old statement after u got connected.Try the same old command,i guess the problem was with the memory mapping to the corresponding object.
    anandkl
    anandkl
    got same problem when I got reconnected. The strang thing is that if I used only ONE upper function in the query, either in WHERE or ORDER BY, didn't have any problem.
    zm
    Belgium
    found on metalink :
    fact: Oracle Server Enterprise Edtion 9.0.1.0.1
    symptom: Errors selecting from a table
    symptom: ORA-7445: exception encountered: core dump [evaopn2()+1104]
    [SIGSEGV] [Address not mapped to object] [0X0] [] []
    symptom: DBMS_STATS have been gathered for the table
    symptom: Optimizer mode set to cost based
    symptom: Column constraint of UPPER used in table
    cause:
    ORA-7445: [EVAOPN2()+1104] error reported when select
    statement using cost based optimizer and statistics is also on the table
    fix:
    Fixed in RDBMS 9.2
    Workarounds:
    Use Rule based optimizer
    or
    Set parameter optimizer_features_enable=8.1.7
    or
    Set parameter compatible="8.1.7"
    or
    Set ALTER SESSION SET EVENTS '10195 trace name context forever,level 10';
    Apr 2002
    Phoenix, AZ
    There have been problems with function based indexed in both initial versions of 8.x and 9.x.
    Refer to patch read files whether there is a fix for Function Indexes. 9.2 should probably fix the problem
    Sridhar R Patnam
    Jun 2003
    Analyse the tables statistics after creating the index and this may sort it out.
    you need the following parameter to use function-based index:
    query_rewrite_enabled = TRUE
    query_rewrite_integrity = TRUSTED
    Colorado Springs
    DBMS_STATS allso has problems with FBI's -- might have to use the old ANALYZE statement there.
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
