I have created a Database with some tables,sequences,triggers,indexes,etc...and I have to send it to a client.
What do you recomend me to do?
Should I create a .dmp file and send it,so the client can import it or do you think there's a better way?
Thanks in advance
But it doesn't work.I don't know why.When I click on the .bat file,DOS window appears and it drives crazy,running and running...
I have done it this way other times.
Yes,my user,password and sevice name are ok.
In fact,I try to execute the .bat file in my desktop (just to try it...) and happens what I told you before.But if I copy another exp file from one of my Oracle folders,that works properly,and try to execute it in my desktop,it happens the same crazy thing...
I tried to create the .bat file in the server desktop,or an oracle server folder,but it's useless...
