    Hi All
    I have problem related to listener. On my machine I have Oracle 8.1.5 on RH 6.2. When I issued the command $ lsnrctl I got the following error message
    lsnrctl: error in loading shared libraries: libskgxp8.so: cannot open shared object file: No such file or directory
    I have downloaded the library from rpmfind.net and installed it from root user on my machine. My file libskgxp8.so is located in $ORACLE_HOME/lib.
    However still when I say $ lsnrctl then I get the above error. Is that file is not used or what? I have also restarted my machine but it is still not working.
    Amol
    Oct 2001
    Add thie line to your .profile and it should take care of that problem.
    export LD_LIBRARY_PATH=$ORACLE_HOME/lib;
    Susan
    I already have these settings in my .bash_profile. But it is not working. Does anyone has the solution for this problem
    LD_LIBRARY_PATH=/u01/app/oracle/product/8.1.5/lib; export LD_LIBRARY_PATH
    Amol
    Hi all
    isn't there any solution? right now I cam access any remote db from my machine but it is not possible to access my db from anyother machine just bcos of listener problem.
    Thanks in Advance
    Amol
