Insert using a cursor record?
Results 1 to 8 of 8
Thread: Insert using a cursor record?
    Nov 2001
    New Brunswick, NJ
    Is it possible to insert into a table
    using the record loaded from a cursor?
    declare
    cursor c_cursor is
    select a,b,c from table;
    for c_rec in c_cursor
    loop
    insert into new_table (using record???)
    end loop;
    end;
    Paul
    Yes.
    Nov 2001
    New Brunswick, NJ
    okay...
    How do I code it?
    Sep 2001
    NJ, USA
    declare
    cursor c_cursor is
    loop
    insert into new_table (a_new, b_new, c_new)
    values (c_rec.a,c_rec.v,c_rec.c);
    end loop;
    end;
    Nov 2001
    New Brunswick, NJ
    what I was really after was to not to have to specify each of the value fields.
    something like
    insert into new_table record;
    and have record represent all of the indivual fields.
    It's just a pain because some of my cursors contain dozens of fields and it takes awhile to specify each and every field after the values clause.
    Thanks for the help.
    Paul
    No Pain, No Gain.
    Sep 2001
    NJ, USA
    Originally posted by mrpaulwass
    what
    something like
    U can't do it.
    in INSERT statment u must wrile VALUES and specify LIST of values.
    regardless of u use scalar variables or object types or variable arrays..
    Nov 2001
    New Brunswick, NJ
    Thanks...
    Lazy programmer, always looking for a shortcut. That's me.
    P
