Thread: PL/SQL problem
    Chicago IL
    I am having a pl/sql problem. Getting this error message:
    declare
    ORA-00937: not a single-group group function
    ORA-06512: at line 3
    ORA-06512: at line 14
    pl/sql
    declare
    cursor cursor_rollbackmonitor_cache is
    select class, count
    from v\$waitstat
    where class in ('free list','system undo header','system undo block',
    'undo header','undo block');
    any ideas?
    "High Salaries = Happiness = Project Success."
    Apr 2002
    Try this...
    FOR CUR IN (select * from v$waitstat where class in ('free list','system undo header','system undo block', 'undo header','undo block'))
    LOOP
    DBMS_OUTPUT.PUT_LINE(CUR.CLASS ||' : '||CUR.COUNT);
    END LOOP;
    Hope, it helps you
    Chicago IL
    hi..it worked but i am getting bunch of other errors.
    systemblock_count boolean;
    ERROR at line 9:
    ORA-06550: line 9, column 2:
    PLS-00103: Encountered the symbol "SYSTEMBLOCK_COUNT"
    ORA-06550: line 44, column 0:
    PLS-00103: Encountered the symbol "end-of-file" when expecting one of the following:
    function package pragma procedure form
    ========pl/sql====================
    for cur in (select * from v$waitstat where class in ('free list','system undo he
    ader','system undo block','undo header','undo block'))
    loop
    dbms_output.put_line(cur.class || ';'||cur.count);
    end loop;
    end;
    monitor_cache_rec cursor_rollbackmonitor_cache%rowType;
    open cursor_rollbackmonitor_cache;
    freelist_count := false;
    systemblock_count := false;
    loop
    fetch cursor_rollbackmonitor_cache into monitor_cache_rec;
    exit when cursor_rollbackmonitor_cache%notFound;
    if cursor_rollbackmonitor_cache%Found then
    if ((monitor_cache_rec.class = 'free list') AND (monitor_cache_rec.count <= 10) ) then
    freelist_count := true;
    end if;
    if ((monitor_cache_rec.class = 'system undo block') AND (monitor_cache_rec.count <= 10) ) then
    systemblock_count := true;
    end if;
    end if;
    end loop;
    close cursor_rollbackmonitor_cache;
    if ( (freelist_count) OR (systemblock_count) ) then
    loop
    dbms_output.put_line( ' Count for '||monitor_cache_rec.class||' = '||to_char(monitor_cache_rec.count) );
    end if;
    end loop;
    end if;
    end;
    spool off;
    exit;
    Apr 2002
    This will work for your requirement.....
    DECLARE
    freelist_count boolean;
    FOR monitor_cache_rec IN (select * from v$waitstat where class in ('free list','system undo header','system undo block', 'undo header','undo block'))
    LOOP
    end if;
    end if;
    END LOOP;
    LOOP
    END LOOP;
    end if;
