    Mar 2002
    Is there any way in ORACLE8i /on HPUX to launch the operating system level command using PLSQL .
    I am trying to accomplish the following
    [1] copy a text file from one directory to another directory
    [2] Open the text file useng PL/SQL and read the file line by line and store it into the database table
    Please help.....
    Reading, U.K
    Cool
    for point 1, i.e., for running an os command, either
    a. write a c program or
    b. write a java program and convert it into a java stored procedure.
    for point 2, use the UTL_FILE package for reading the text file.
    hth.
    Cheers!
    OraKid.
    Mar 2002
    you could also use utl_file to copy
    the file by opening and reading and
    writing it to a new directory. Make sure
    init.ora parameter for utl_file is set
    properly.
