Rebuild index in Production
Thread: Rebuild index in Production
    I am going to rebuild all Production Database indexes with a batch job. I want to know that do I have to run one of these
    commands after rebuild finish :
    ANALYZE INDEX COMPUTE STATISTICS;
    ANALYZE TABLE COMPUTE STATISTICS FOR ALL INDEXED COLUMNS
    Also I want to know because couple of tables are really big is it any problem can happen? For example I think I need a big Temp Tablespace !! Please advice what safety cution I have to take into effect ?
    An ounce of prevention is worth a pound of cure
    You don't need to run analyze command separately.
    In the "CREATE INDEX ...." script add compute statistics ;
    This is faster than running the analyze command.
    I don't use create index , I want to user "ALTER" INDEX ....REBUILD . Also what I have to choose for next and first extent ( Rule of thunmb ? )
    Ensure you have created a big temp tablespace for sorting, if you are using CREATE INDEX statement.
    Example for ALTER INDEX:
    ALTER INDEX SALES_IDX REBUILD
    TABLESPACE TS_IDX
    STORAGE ( INITIAL 20M NEXT 20M PCTINCREASE 0)
    PARALLEL NOLOGGING COMPUTE STATISTICS;
    ALTER INDEX SALES_IDX LOGGING;
    The INITIAL and NEXT value depend upon the table size.
    Oct 2001
    Kuwait
    Post Guidelines for rebuilding indexes
    Guidelines for rebuilding Index.
    Find out indexes that are fragmented
    1) select TABLESPACE_NAME , SEGMENT_NAME , COUNT(*)
    from DBA_EXTENTS
    where SEGMENT_TYPE = 'INDEX'
    group by TABLESPACE_NAME , SEGMENT_NAME HAVING COUNT(*) > 5
    ORDER BY 3 DESC
    this SQL gives you indexs that are fragmented. Change the
    group predicate condition if you wish
    2) analyze index validate structure
    will analyze the index structure
    3) select * from index_stats
    will display the computed statistics. Some significant fields are
    HEIGHT, BLOCK ,
    computed value for DEL_LF_ROWS /decode( LF_ROWS,0,1,LF_ROWS ))*100
    ( According to Oracle for any index, if HEIGHT > 4 or the computed ratio is greater than 25 then the index is a candidate for rebuild.)
    4 )select name , value from v$parameter
    where name = 'db_block_size' . This will give the value of
    db_block_size.
    5 ) Rebuild the index
    alter index rebuild tablespace
    strorage (initial comp_val1 , next comp_val2 , pctincrease 0 )
    comp_val1 = BLOCK ( generated in step 3 ) * value of db_block_size
    comp_val2 = comp_vale1/2
    6 ) If needed create a PL SQL script to autmatically perform all these
    steps and run it when the work load on the server is low.
    Oracle DBA
    National Bank Of Kuwait
