problem with set_block_property forms6i
Thread: problem with set_block_property forms6i
    Mar 2002
    Unhappy
    i want to the back ground color of few records to change based on the value
    for example i have a form in tabular form and 10 records are displayed
    i want to change the background color of those reocrds where the deptno is 10 and i want this to happen when i execute query..
    i tried all the ways but i cud'nt .....
    i am able to do it..record by record..int eh when_new_record_instance tirgger..but not the other way around.
    bob
    Sep 2001
    NJ, USA
    U should use SET_ITEM_INSTANCE_PROPERTY
    DECLARE
    cur_itm VARCHAR2(80);
    cur_block VARCHAR2(80) := :System.Cursor_Block;
    BEGIN cur_itm := Get_Block_Property( cur_block, FIRST_ITEM );
    WHILE ( cur_itm IS NOT NULL ) LOOP
    cur_itm := cur_block||'.'||cur_itm;
    Set_Item_Instance_Property( cur_itm, CURRENT_RECORD, VISUAL_ATTRIBUTE,'My_Favorite_Named_Attribute');
    cur_itm := Get_Item_Property( cur_itm, NEXTITEM );
    END LOOP;
    1) create special visual attribute
    2) use this attribute in Set_Item_Instance_Property procedure.
    Mar 2002
    thanks it works
    hi ,
    it works thanks a lot....
    gr8
    cheers
    bob
