    Mar 2002
    hi
    i m new here...I have cleared the first two papers in OCP 8i DBA. I take exactly one month to finish each paper.
    Wow ...u folks really ripped that fellow from japan asking for ILT's.
    I am right now studying for 1Z0-026.
    Below are few questions ....which I can't figure out the answers. Kindly help me.
    I have marked my answers....do correct me if I m WRONG.
    Please note these questions are NOT DUMPS.
    1>when is a request sent to the listener
    a) after every call *****
    b)before every call
    c)after name resolution
    d)before name resoluation
    2>Which parameter is specified in Server and Client in Local Naming method
    a) protocol
    b)database alias *****
    c) sqlnet.ora
    d)tnsnames.ora
    3>Net8 Assistant can be used to configure a region database to be used by a Names Server. Which two methods can be used to populate the database with service name? (Choose Two)
    A.*Net8 Assistant can be used to load service name.
    B.Service names can be read from an existing sqlnet.ora file.
    C.*Service names can be read from an existing tnsnames.ora file.
    D.Service names can be loaded by issuing the NAMESCTL>reload command.
    E.Service Names are loaded dynamically when the Names Server is restarted
    4>Net8 should first try to resolve the service name according to the local naming method. What is the correct implementation?
    A.names.directory_path=(ALL)
    B.*names.directory_path=(HOSTNAME)
    C.names.directory_path=(TNSNAMES, HOSTNAME)
    D.names.directory_path=(HOSTNAME, TNSNAMES)
    5>Net8 Assistant can be used to configure a region database to be used by a Names Server. Which two methods can be used to populate the database with service name? (Choose Two)
    6>How many response queues are present in a multithreaded server environment?
    A.One per system.
    B.One per database.
    C.One per listener.
    D.*One per dispatcher.
    7>Which two methods could you use to add service names to a region database? (Choose Two)
    A.Manually add them using Net8 Assistant.
    B.*Restart the service names with the new region database.
    C.Download them from another Names Server using Net8 Assistant.
    D.*Load them from another file using the Net8 Assistant Names Server section.
    E.Add new service names to the Net8 Assistant names net service names section
    thankx
    Dec 2001
    New Jersey
    Kunal,
    o.k., some of these questions are weird...and redundant...but here we go:
    1. Wrong: C. After Name Resolution
    2. Weird question, but my best guess is either 'Protocol' or 'SQLNET.ora'
    3. Correct
    4. Wrong: C. TNSNAMES needs to be specified first for LOCAL...HOSTNAME is for the host naming method.
    5. Correct (same question as #3)
    6. Correct...one response queue per dispatcher (total of one request queue...regardless of number of dispatchers.)
    7. poor question...close to #3 and #5...correct answers are A & D.
    Edward Haskins, OCP
    OraKnowledge, Inc.
    www.oraknowledge.com
    --"Live" Instructor-led Online Training for Oracle9i, Java and XML--
    Oct 2001
    Toronto, Canada
    Kunal!
    Do a search on this forum. There were a few threads with Net8 questions. Net8 was the easiest exam for me so far. Good luck.
    Leo
    Oracle 8i OCP DBA
    Toronto, Canada
